Solved Smart Move or Dead End? Migrating Legacy DA License to Ubuntu 22.04 + Ubuntu Pro (ESM)
chmuri
Hello community,
I'm currently planning an infrastructure migration and running into the well-known "Legacy License vs New OS" dilemma. We all know that DirectAdmin Legacy licenses are technically hard-locked and won't play nice with Ubuntu 24.04 or newer due to distro-upgrade-lock and glibc/OpenSSL compatibility issues.
However, I have a specific architectural idea in mind, and I’d love to get some feedback from fellow sysadmins before pushing it to production.
📋 The Plan:​
Instead of upgrading to Ubuntu 24.04 and forcing a license conversion to the new Unified Standard tier ($15/mo promo), I’m thinking about migrating to a clean Ubuntu 22.04 LTS instance and immediately attaching it to Ubuntu Pro (which is free for up to 5 machines).
By enabling Ubuntu Pro with Expanded Security Maintenance (ESM), the underlying operating system (kernel, base libraries, core packages) will receive official security patches until 2032, effectively bypassing the standard April 2027 LTS EOL.
❓ My Questions & Concerns:​
While the OS itself will stay secure for years, I have serious doubts about how DirectAdmin and CustomBuild will behave in the long run under this setup.
  1. CustomBuild Software Limitations: Even if Ubuntu Pro keeps the core OS secure, what happens to the software stack compiled via CustomBuild? Since Legacy DA is essentially under a feature freeze, will CustomBuild eventually stop pushing updates for Apache/Nginx, MariaDB, Exim, and Dovecot for Legacy license holders?
  2. The PHP / Library Wall: As time goes on, newer PHP versions (like PHP 8.4+) will require newer compilation dependencies (e.g., modern versions of libxml2, sqlite3, or newer gcc compilers). Since Ubuntu 22.04 will lock these packages to older major versions (even with ESM patches), will CustomBuild simply fail to compile future PHP/webserver versions on a Legacy license?
  3. Internal Hard-Locks: Does DirectAdmin hard-lock certain CustomBuild software sub-versions based purely on the license type, even if the OS is theoretically capable of compiling them?
Has anyone tried this specific combo (Legacy DA + Ubuntu Pro ESM) to extend the lifespan of their non-subscription setups? Are there any hidden gotchas or artificial blocks within CustomBuild that I should be prepared for?
Looking forward to your insights and experiences!
Cheers!
Are you literally using chatgpt - ai to type this for a €15 per month license?
You are right its nonsense . But if i just asked a question but for 100+ installation, then yes its matter from business perspective and clients perspective. But thanks for interest.
Issue resolved migration to ubuntu 26.04 plus Ubuntu Pro license will extend next migration for few years later.
You might compare the case with CloudLinux/CentOS 6/7. CloudLinux still pushes updates for EOL'ed versions. But neither CloudLinux/CentOS 6 nor 7 receive updates from DirectAdmin, since they are EOL.
As soon as a specific version of Ubuntu reaches EOL, they will stop receiving updates from DirectAdmin as well. It would mean none of installed services, whatever they are Apache, Nginx, Exim, Dovecot will receive updates from DirectAdmin. And you will be stick to the specific versions without updates.
Of course it is possible to compile software manually and/or even install packages from an OS repository. I won't even try and evaluate on how much you will benefit from it.
Check the page https://docs.directadmin.com/operat...l/#supported-operating-systems-and-eol-policy for EOL dates.
Exactly, and that’s precisely why we made the switch to Ubuntu. The magic of do-release-upgrade followed by a simple CustomBuild rebuild makes in-place upgrades incredibly smooth.
Unless you strictly need CloudLinux features like CPU jailing (LVE) or MySQL Governor, Ubuntu is hands down the better choice for in-place OS upgrades. We stuck with the RHEL ecosystem for years, but the lack of a reliable, native in-place upgrade path eventually killed that solution for us.
Even today, if you have an old Ubuntu 14.04 instance, you can still run apt-get update and it just works (via old-releases), whereas with CentOS 7? You can completely forget about finding active, working mirrors without extra manual hassle.
