DirectAdmin 1.705
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.705.
DirectAdmin 1.705​
A new build is released. It improves compatibility with wildcard certificates issued for parent domains. It allows domain like example.com to use certificate that was issued for *.com. Such situation is only possible with manually managed certificates. Automatically issued certificate for example.com would have names example.com and *.example.com.
This problem exists longer, but when you type something in the search bar something with a capital letter it will not find it. For example User1 will not find something but user1 will.
Today`s received package updates for Cloudlinux8 want liblsapi 1:1.1-95 but DA on stable channel provides 1:1.1-94
when we can expect new liblsapi?
package criu-lve-4.2-4.el8.x86_64 from cloudlinux-x86_64-server-8 conflicts with liblsapi < 1:1.1-95
already available: https://changelog.cloudlinux.com/liblsapi
It seems I was too fast ))
It is already fixed in DA version 1.706 (ALPHA release):
[root@server2 ~]# grep lsapi /usr/local/directadmin/custombuild/versions.txt
mod_lsapi:1.1-94:
[root@server2 ~]# da update alpha
updating to directadmin alpha 1.706 2e54cba0ac4ab00b180710b471321d71cf441786
[root@server2 ~]#
mod_lsapi:1.1-96:
[root@server2 ~]#
The file manager shows the ctime field as 'Last Modified', but this should be the 'mtime' field to match with 'ls -al'.
mtime -> when was the content changed, same as 'ls -al'
ctime -> when was inode-meta data changed. (copied, links, owner, permissions etc)
1.705 still have mod_lsapi 1.1-94, why fresh 96 version not added to stable channel?
A new build is released with Exim version updated to 4.99.5,
And what about: 1.705 still have mod_lsapi 1.1-94, why fresh 96 version not added to stable channel?
I can't update other OS packages. Is it safe to manually change version to 96 but stay on stable 1.705?
You can customize the version of MOD_LSAPI in such way:
echo "mod_lsapi:1.1-96:" >> /usr/local/directadmin/custombuild/custom_versions.txt
da build mod_lsapi
@fln CSF still has an incorrect path to the error log file. In my opinion DIRECTADMIN_LOG_R should has path /var/www/webapps/*/logs/errors.log
No it's good. Seems DA has change the roundcube log to /var/log/roundcube and csf is pointing to that too. Check it out, it's all fine. At least on Alma. Might be fixed on the newer version DA, but in my case it's all good (DA 1710).
