DirectAdmin 1.706
Ok, 24 hours later, it cleared..... Now it shows two certificates, one for my main domain (wildcard), and one for my pointer domain (wildcard).
Do I assume that when the next renewal of my main domain comes, it will not include my pointer domain for that certificate?
Domain and pointer certificates are issued separately in order to not leak information about each other.
Only the domain + subdomains, and (each) pointer + subdomains, are combined into their respective certificate.
How about domain name and seperate hostname entry's like domain example.com with wildcard ssl and seperate entry in DNS manager for server.example.com? Won't that give conflicts?
Because until now I just selected ftp and www etc. so no wildcard on example.com and then a seperate ssl certificate on server.example.com to prevent conflicting issues.
As a provider running many servers on DirectAdmin (9, soon 10 servers, a couple thousand sites), I want to share our recent experience with SSL, since fln asked for corner cases and I think the full story is useful.
For a while we were dealing with a recurring problem, several support tickets and customer complaints a day. Domains kept ending up in an inconsistent state: ssl=ON in the config but no certificate files, with the automatic retry looping and then giving up.
On one server we found 93 domains stuck like that, and 92 of them no longer had a .next_retry file, so DA had stopped trying and left them dead.
The worst part for us was what the customer saw: the generic "Could not execute your request" in the panel, while the real cause (Ssl::getKeyBit ... .key: No such file or directory) stayed hidden in a log they never open. That is a product-quality issue more than an ACME issue, and at our scale it quietly erodes trust in the platform.
While digging we found a second, distinct way into the same broken state: a per-domain .dnsprovider file with dnsprovider=cloudflare but empty token values. DA read it, forced DNS-01, and hard-failed with "credentials missing" instead of falling back to HTTP-01, which worked fine for that domain (it is behind Cloudflare and the challenge round-trips to the origin). So DA persisted a provider config it could not use and then refused the method that would have succeeded.
Then we updated to 1.706 and hit a third one. On one of our 1.706v servers, data/admin/letsencrypt_rate_limits/weekly.json was 0 bytes, and that blocked ALL certificate issuance on the entire server: every request failed with error=decoding data/admin/letsencrypt_rate_limits/weekly.json: EOF, same generic error for the customer. Resetting the file to [] fixed it instantly and DA repopulated it from there. Only 1 of our servers on 1.706v was affected, so it looks like an init edge case, but a single empty JSON file taking down all issuance is exactly the kind of fragility worth removing. Reading that file should tolerate empty or missing and treat it as zero usage.
Where I would push, would be:
  1. Make the failure paths robust. An empty or corrupt rate-limit file, or an unusable DNS provider config, should never take down issuance or dump a domain into a broken ssl=ON with no certificate. Fail safe, and surface the real reason instead of "Could not execute your request."
  2. Give us a CLI for the new system. I want to second Ohm J and sparek here. letsencrypt.sh request now only enables ACME, and there is no supported CLI to force a provisioning run or query per-domain status and failure reasons. For multi-server operators, web-UI-only does not scale. We rely on scripting for fleet operations, migrations, and repairs like the ones above. A CLI to enable/disable ACME per domain, force a provision, and query status would make a real difference. If there is already, do let me know, maybe i'm missing something.
We are invested in DirectAdmin for the long run, which is exactly why I am taking the time to write this.
Thanks @Zhenmue.
Quick note regarding the weekly.json file. If this file is empty both systems old and new stops with an error since DA 1.699.
It was reported multiple times already. The reason we are still failing when this file is empty is because we are still trying to find out who is creating the empty files. DA itself never leaves this file empty (it creates temporary file with other name, writes to it and renames it atomically). This means that full disk or DA killed at any point in time will never leave this file empty. We think it could be caused by some plugins but still have not found the culprit.
The CLI ways still works, running letsencrypt.sh script will enable the new system and will issue certificate immediately. You can continue using it for automation. The only difference from the old letsencrypt.sh is that it will not reissue new certificate if there is an already valid (and with same DNS name) certificate already issued.
The script also shows the verbose output of certificate issuance command so you can continue using it for debugging.
We will improve the DNS provider configuration part. Thanks.
Some fields should automatics detect if key have "api" or "token" text, when loading the exists value, should marks the value as "******" and any API response, to prevent secret/sig steal from account hijacking, like accident re-use password from other application compromise.
More issued: it's should automatics detect is it enable or not from the old version SSL "SSL Certificates" management, otherwise some site won't get auto-renew anymore and mostly some user might complain their site are broken due SSL.
Thanks @Zhenmue.
Thanks fln, that is really helpful.
Our data point for the culprit hunt: on our affected server the empty weekly.json was a single event, not recurring. It sat at 0 bytes with a frozen mtime for about three weeks until we reset it to [], and it has repopulated and stayed healthy since. We checked everything we add to the server (our antispam plugin, cron jobs, custom scripts) and none of them reference that path, so on our end it looks like a one-time truncation rather than an ongoing process. The server runs several plugins including jetbackup5 and backuply.
Good to know letsencrypt.sh still works for automation and issues immediately, we will keep using it for our fleet tooling.
On "we will improve the DNS provider configuration part", here is a concrete case we just hit, since it may be related. A domain had a per-domain .dnsprovider file with dnsprovider=acme-dns and no credentials set. The new system forced DNS-01, tried a wildcard *.domain, and failed with acme-dns: some credentials information are missing: ACME_DNS_API_BASE. It never fell back to HTTP-01, which works fine for that domain. Worse, after repeated failures the system added every DNS name of the domain to the acme_skip_dns_names exclusion list, so nothing provisioned at all, and removing a couple of names from the list in the panel was not enough. Removing the .dnsprovider file (so it fell back to HTTP-01) and clearing the exclusion list fixed it immediately. So for that improvement: please do not persist a provider config without valid credentials, fall back to HTTP-01 when the configured provider is unusable, and do not poison the whole domain's exclusion list from a provider-config failure.
The main server TLS certificate and Domain certificates live in separate directories and used in different places. There should be no conflicts.
DirectAdmin 1.706, EL8, webserver=openlitespeed. Running update_versions (OLS 1.9.0 → 1.9.1) destroyed my OpenLiteSpeed installation and left the web server unable to restart.
From the per-run log (custombuild.1784754867.*.dXBkYXRlX3ZlcnNpb25zAA.log): the installer re-points the /usr/local/lsws symlink to the new staging dir, then rm -rfs the old install dir before extracting the new tarball. Because LSCache data (cachedata/priv/) lives inside the versioned install dir, the still-running OLS was writing cache files during the delete, causing rm: cannot remove ... Directory not empty errors. That nonzero exit aborted the install before extraction — leaving /usr/local/lsws as a dangling symlink and the old install already deleted. update_versions then continued to the next package without reporting any failure.
Three issues: (1) the old install is removed before the new one is extracted/verified — the failure window leaves no working server; (2) the delete races with live LSCache writes, which is near-guaranteed on any busy server with lscache enabled; (3) the failure is swallowed instead of aborting/rolling back. Log excerpt:
Updating OpenLiteSpeed
download_cached: downloading '...openlitespeed-1.9.1-x86_64-linux.tgz' (100.0%)
Installing OpenLiteSpeed 1.9.1...
removing /usr/local/lsws-PdXa
rm: cannot remove '/usr/local/lsws-PdXa/cachedata/priv/5': Directory not empty
rm: cannot remove '/usr/local/lsws-PdXa/cachedata/priv/c': Directory not empty
rm: cannot remove '/usr/local/lsws-PdXa/cachedata/priv/3': Directory not empty
rm: cannot remove '/usr/local/lsws-PdXa/cachedata/priv/f': Directory not empty
rm: cannot remove '/usr/local/lsws-PdXa/cachedata/priv/d': Directory not empty
Updating Composer ← moved on, no error, no "installation complete"
  • Like
Reactions: fln
