digignosis
- May 15, 2023
From the 1.706 release notes: "The Evolution skin in this release supports only using the new ACME system."
So in the next release the other options will be back? I know they're available in the old skin, but this is just needlessly erasing much needed and unique functionality, without a viable replacement.
Here's a problem for instance: when changing a domain name via Domains > Rename domain, I'll need a new certificate, since the domain name has changed. I delete the old certificate (since it's the wrong domain name), turn on ACME, and press "Provision now".... still waiting after 14 hours, spinner spinning, and the "provision now" button stays greyed out. And there's no options to manage this otherwise.
I used to be able to simply select certificate domains (like domain.com and www.domain.com) for lets encrypt, press "save" and I'd have new, working certificate literally in 3 to 15 seconds (!)
And this is very necessary when planning domain name changes or website transfers. Please restore the professional options to handle lets encrypt certificates directly (and quickly), it can't be too much work I assume, since it's a skin-only issue.
Thank you, very much, for looking into this.
