dorucrisan
Starting today, DA can not unzip zip file created with DA. What is happening? I tried on 2 servers, same issue, both servers updated running Alma Linux 10 + DA. All worked fine until today.
will do thanksPlease open a support ticket. There were not changes in the archive handling for a while. It is unlikely to be related to the server update.
You can try checking your /home/ folder to find out which directory is the largest:Problem solved. All was because for unknown reason /home went to 100%. Any idea what can cause that? Server is hosting 2 Prestashop web shops nothing else and there is plenty of space, like 500G hard drive. One store is around 10-11G.
du -hs /home/* | grep -E 'M|G
ncdu /home
Thank you so much, will try.You can try checking your /home/ folder to find out which directory is the largest:
and then check that the largest folder again. And as the result you will come to the place which uses a lot of disk space.Code:du -hs /home/* | grep -E 'M|G
Also you can use "ncdu" command:
It works faster, but it should be installed additionally via YUM or APT OS package manager.Code:ncdu /home
