I can't see php selector in the panel after install PHP 8.3
Dimitris1
Athens, Greece
Hi there,
I install php 8.3 via
cd /usr/local/directadmin
da build set php1_release 8.3
da build php
da build rewrite_confs
following this guide
https://docs.directadmin.com/webser...elect-between-multiple-different-php-versions
If you want to continue using LSPHP as PHP Mode,
then you need to skip this command: da build set php1_mode php-fpm
because i use OpenliteSpeed as web server. = php1_mode = lsphp
but after finish the setup , i can't see the php selector .. please look at screenshots
In order to have a PHP selector enabled, you will need to install more than one PHP version in DIrectAdmin. The article you are referring to describes how to install multiple PHP versions. You might follow it.
Where that point the instalation multiple PHP version ..? i can't find where he says it .
the same place as you mentioned in the very first post in the thread, i.e. CLI or SSH
In the guide it starts from the words "The following is a sample installation of multiple PHP versions:"
THanks, i find it before but you post faster then me.
You think PHP 8.4 and 8.5 is safe to exist as option ..?
Btw, i run all the domains by my self.
