Hi all, is it true that the latest DirectAdmin cannot install SSL files from Zerossl? The common name always points to the host server, not to the dedicated IP.
I would not say it is true. If your domains point to a wrong IP (even if it's a the host's one), then you should check your IP assignment and DNS records (specially if you use remote nameservers).
Hello, I would not say it is true. If your domains point to a wrong IP (even if it's a the host's one), then you should check your IP assignment and DNS records (specially if you use remote nameservers).
Not domain sir, I user ip for website example 162.33.33.1
I create ssl on zerossl and file ssl cannot resolved, but in this case DirectAdmin 1.706 has a known bug where it doesn't update the web server config after uploading — so a manual server-side fix ssl
