Solved How can I block this spam coming via Google?
I checked logs across all our servers and we’re no longer seeing new spam from these Google Groups reaching customer inboxes — most of it is now being caught by the spam filter rule mentioned earlier.
The KAM.cf rules also made a noticeable difference.
If these messages are still getting through on your side, it’s worth checking your scoring setup. For example, if your required score is around 8, make sure your custom rule like HK_GOOGLE_GROUPS is set significantly higher (e.g. 10+) so it guarantees a hit.
Here’s an example of how these messages are being scored on our side:
spamd: result: Y 19 - DKIM_SIGNED,DKIM_VALID,DKIM_VALID_AU,DKIM_VALID_EF,GB_URI_ASTERISK,HK_GOOGLE_GROUPS,HTML_FONT_SIZE_HUGE,HTML_IMAGE_ONLY_08,HTML_MESSAGE,HTML_SHORT_LINK_IMG_1,MAILING_LIST_MULTI,RCVD_IN_MSPIKE_H2,SPF_HELO_NONE,SPF_PASS,URIBL_ABUSE_SURBL,URIBL_DBL_BLOCKED
So even though the messages pass SPF/DKIM, the combined rule weight (especially HK_GOOGLE_GROUPS) pushes them well over the threshold.
Here’s another example showing the same pattern — note how everything passes SPF/DKIM/DMARC, yet the message is still clearly spam and gets caught mainly due to the Google Groups rule:
Return-path: <[email protected]>
Envelope-to: hello@<domainremoved>;
Delivery-date: Tue, 28 Apr 2026 18:04:28 +0200
Received: from mail-yw1-f200.google.com ([209.85.128.200])
by <server removed> with esmtps (TLS1.3)
(Exim 4.99.1)
for hello@<domainremoved>;
Authentication-Results:
dkim=pass;
spf=pass;
dmarc=pass;
Precedence: list
Mailing-list: list [email protected]
List-ID: <hs.chinacvcn.com>
X-Google-Group-Id: 806615142161
X-Spam-Score: 11.7 (required 8.0)
And the key part from the SpamAssassin breakdown:
pts rule name description
10.0 HK_GOOGLE_GROUPS Message sent via Google Groups
1.9 URIBL_ABUSE_SURBL URL listed in blocklist
0.5 LOCAL_HTML_ONLY_HIGH HTML-only message
0.2 HEADER_FROM_DIFFERENT_DOMAINS
-1.0 MAILING_LIST_MULTI
Even though authentication is clean (SPF_PASS, DKIM_VALID, DMARC_PASS), the message still scores 11.7, mainly due to:
HK_GOOGLE_GROUPS (custom rule doing the heavy lifting)
URIBL hit
Typical HTML-only / list characteristics
Without a strong rule like HK_GOOGLE_GROUPS, this would likely slip through on many default configurations.
As stated before, the reason is that the mails are too big and therefor not scanned by Spamassassin, my score was already set to 10.
That's also the reason that only a few big mails came through amongst with the chinacvcn.com mail too which was 6M in my case.
A stronger rule will most certainly not help if SA doesn't even scan the mail. So the solution to this is either wait for DA 1.700 or for the time being raise the limit for which Spamassassin will scan a mail in the /etc/exim.easy_spam_fighter/variables.conf.custom file like this:
EASY_SPAMASSASSIN_MAX_SIZE == 10M
or a bigger value, and rebuild the exim configuration.
Before I had this set to 2M and most mails were blocked, except the ones bigger, because SA did not even scan them due to this setting.
However, with DA 1.700 this issue will be passed, we just don't need to forget to remove the setting in the variables.conf.custom file after updating to Directadmin 1.700.
It seems not removing the custom setting brings exim down in the new update version.
Maybe try with a single = character as it's a setting now and no overrule setting anymore as the default setting is gone with the update.
If that still does not work and you want to use a limit, you might want to notify fln in the releasse thread because he said everything should keep working as is.
I found out that if you have an valid google account, you can opt out (somewhere in the settings, just cant remember in detail) for those google groups messages at all.
I see those google group spam messages arrive on email addresses that do not have a google account.
Beats me to how that's allowed by google..
Also tried to report it many times to google, but pretty sure it all goes to /dev/null, so now added a spamassassin rule as was mentioned earlier in this thread
If I'm correct it's just send by Google. I know Google can pickup mail from other domains. I thought maybe it's picking up mail from other domains and then sending it, because the sender domain address is not from Google, only the MTA address.
We also report all of these mails via Spamcop to Google. Also the Spamassassin rule is present, but seems less effective for some reason. Probably because they are not using google cloud now but plain Google.
