Preventing malicious traffic from bc.googleusercontent.com
Remco00
Lately I have seen an increasing number of malicious traffic from bc.googleusercontent.com in the log files. Almost always starting with the IP4 addresses 34.* and 35.*. That's why I went looking for an overview of IP addresses managed by Google. I found this one here:
https://www.gstatic.com/ipranges/goog.json
After stripping unnecessary text, I copied this list of Google IP-ranges to csf.deny:
# Google IP ranges
tcp|in|d=80,443|s=34.0.0.0/15
tcp|in|d=80,443|s=34.2.0.0/16
tcp|in|d=80,443|s=34.3.0.0/23
tcp|in|d=80,443|s=34.3.3.0/24
tcp|in|d=80,443|s=34.3.4.0/24
tcp|in|d=80,443|s=34.3.8.0/21
tcp|in|d=80,443|s=34.3.16.0/20
tcp|in|d=80,443|s=34.3.32.0/19
tcp|in|d=80,443|s=34.3.64.0/18
tcp|in|d=80,443|s=34.4.0.0/14
tcp|in|d=80,443|s=34.8.0.0/13
tcp|in|d=80,443|s=34.16.0.0/12
tcp|in|d=80,443|s=34.32.0.0/11
tcp|in|d=80,443|s=34.64.0.0/10
tcp|in|d=80,443|s=34.128.0.0/10
tcp|in|d=80,443|s=35.184.0.0/13
tcp|in|d=80,443|s=35.192.0.0/14
tcp|in|d=80,443|s=35.196.0.0/15
tcp|in|d=80,443|s=35.198.0.0/16
tcp|in|d=80,443|s=35.199.0.0/17
tcp|in|d=80,443|s=35.199.128.0/18
tcp|in|d=80,443|s=35.200.0.0/13
tcp|in|d=80,443|s=35.208.0.0/12
tcp|in|d=80,443|s=35.224.0.0/12
tcp|in|d=80,443|s=35.240.0.0/13
tcp|in|d=80,443|s=35.252.0.0/14
Now, after a few days, no more malicious traffic entries (e.g. mod_security) from bc.googleusercontent.com are visible in the log files. In the coming period I will monitor the Google Json file for the frequency of mutations in the file. If necessary, I will supplement my findings here.
List edited with advanced port filtering and specialized pipe-separated rules
I've been seeing the same, and was contemplating the exact same action.
Unfortunately I am a little worried about blocking legitimate traffic, so I was hoping GCP would figure out who's churning through their addresses.
You might want to have a look at this thread. It's set as solved but was a bit ongoing.
I also experiencing again spam via Google and Outlook.
Thanks Richard, but this has nothing to do with receiving spam. The malicious traffic we receive from bc.googleusercontent.com triggers certain mod_security rules we want to get rid of. Meanwhile I edited my first post to include port filtering and specialized pipe-separated rules in the list with Google IP-ranges so only ports 80 and 443 are blocked.
Then it would be unusable if one blocks all google ip's then gMail posts not not be able to be received either. In post #5 it's only Google cloud if I'm not mistaken.
Therefore, we only block certain segments from the list which we recognize from the logs (see my first post #1) and only incoming ports 80 and 443.
An easy way is something like:
# List whatever networks you want (this is goog.json minus the service ranges.
GCP="34.0.0.0/15 34.2.0.0/16 34.3.0.0/23 34.3.3.0/24 34.3.4.0/24 34.3.8.0/21 34.3.16.0/20 34.3.32.0/19 34.3.64.0/18 34.4.0.0/14 34.8.0.0/13 34.16.0.0/12 34.32.0.0/11 34.64.0.0/10 34.128.0.0/10"
# block 80/443. I just block everything because of the three musketeer rule: an a*hole at 443 is an a*hole at all ports, but this is a 2 port version.
for c in $GCP; do
  for p in 80 443; do
    echo "tcp|in|d=$p|s=$c # GCP abuse"
  done
done >> /etc/csf/csf.deny
csf -r
More servers or many more ip's? Drop them in a ipset hash:net block.
