DirectAdmin 1.709
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.709.
DirectAdmin 1.709
Thanks @stefantriep. The empty docs page was a placeholder for the next DA 1.710 release with an incorrect title. The title is fixed now.
After this update, SSL is no longer working correctly for subdomains. I’m getting HSTS errors, regardless of whether I use a wildcard SSL certificate, a regular certificate, or ZeroSSL.
It even requested a new SSL which was not needed.
Every update seems to introduce new SSL-related problems.
@exlhost, could you please share some details or open the support ticket. This is not something we see on our test servers.
@fln After updating to DirectAdmin 1.709, the Brute Force Monitor (evo/brute-force-monitor) is no longer working correctly on my server.
The issue is not limited to the monitor itself — the Brute Force Monitor link does not open/work when clicked, and I cannot access the page through the Evo interface.
This started immediately after the DirectAdmin 1.709 update.
Could you please check whether there is a problem with the Evo Brute Force Monitor route/page in 1.709 and advise how this can be fixed?
DirectAdmin version: 1.709
Affected area: evo/brute-force-monitor
Problem: Link/page does not open or function after the update.
@Can, the BFM page work as expected on our test servers and on the demo.directadmin.com.
Maybe it is something specific to your server. Please open a support ticket and we will investigate it further.
We did that, I followed Roman's steps, you can read my response there. Please note that when we have performed the update from 1.708 to 1.709 again, we will see on the SSL page from the current the SSL certificate: New certificates are waiting to be provisioned.
Thank you @exlhost. The root of the problem was a subdomain that is using the www alias. The new system no longer issues certificates for the subdomains with additional www prefix.
In the next DA release 1.710 (currently in alpha) we are removing the www alias from web server configuration completely. For users who want to continue using subdomains with main name and an additional www alias we added a maintenance task. When executed this task reports any subdomains that have functional www prefixes and allows automatically creating normal subdomains for them. More details here.
Can you elaborate on how the maintenance task knows if the www subdomain is used or is in use?
Does it check the apache-logfile for activity?
Kr
Dries
