Solved Acme ssl cert connection errors
roly
hi
edit: please ignore, finally got it working, whether it was a propogation issue i'm not sure, but all working. thanks anyway
i have one particular domain on the server that for some reason won't issue a letsencrypt ssl cert. i've used this sucessfully for loads of domains on the server but this one wont issue a certificate due to connection errors if i refresh the page it will sometimes offer to provide for www or ftp but not the others, and if i refresh the page again it will offer a cert for maybe smtp but none of the others. i've checked my dns and its correct as far as i can tell and checked propogation which is ok, i'm going round in circles.
i have
_acme-challenge120TXT"persistent-record"
in my other domains, which i have tried adding and that didn't help either.
can anyone see anything wrong in my dns or got any other ideas?
thanks in advance
Might be an issue with DNS resolvers specified in /etc/resolv.conf, but probably the latest DA does not rely on the listed nameservers in the file any longer. Just an idea to check, if anybody else faces the same issue.
thanks for the reply, although the issue is sorted, it's good to know for future problems
