DirectAdmin 1.711
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.711.
DirectAdmin 1.711​
You're probably too aggressive in forcing a 'private_html' removal. There are old servers, which still use public_html and private_html with different content. I understand you need to evolve. But still... just my point
Why do you think someone is deleting private_html? The changelog says they'll simply stop creating that directory for new users going forward.
In fact, they haven't used private_html in their templates for over half a year already:
I don't. Who told you that? No `private_html` can be used since 1.710. I will need to replace a DOCROOT with a CUSTOM TOKEN, if I want to still use `private_html`
- https://docs.directadmin.com/changelog/version-1.710.html#️-all-web-server-templates-use-docroot-token
The web server configuration templates are updated. Key changes:
  • The DOCROOT token will be used for both domains and subdomains. Previous releases used the SDOCROOT token for subdomain document root.
  • Templates will no longer set or change the document root tokens inside the template. The main DOCROOT token will be set by the main DirectAdmin service before the template is evaluated.
  • The tokens REALDOCROOT and PUB_DOCROOT are completely removed. They were defined inside the templates but not used.
  • The token SDOCROOT will still be available. The value of this token will be the same as the main DOCROOT token.
Special care should be taken if the token DOCROOT is being changed in the CUSTOM[N] sections. It is still possible to change the document root by changing this token value. However, since subdomains are now using the token DOCROOT instead of SDOCROOT, a customised main document root can leak into the subdomain configuration.
Ah, you mean the ability to use separate public_html and private_html directories as a concept?
You can still customize your templates to accommodate that - if it's the HTTPS part, use one docroot; if HTTP, use a different one. Basically, the same way you'd customize any main domain's docroot.
Throughout the period when websites started loading only from public_html, we did come across different websites being used between HTTP and HTTPS for some users, but in every case it was accidental - either an old, unused version, or a duplicate copy of the site where the user simply didn't know where to upload their files. Across our entire server fleet, we've had zero cases where this was actually needed.
So far, I haven't heard a valid reason why this separation would actually be needed. With .dev domains, browsers do not even let you access the websites over http:// due to preloaded hsts rules.
It would be probably more user-friendly if you give an option to support legacy private_html within DOCROOT token. You might add additional code in DirectAdmin which will check if private_html folder exists, and set DOCROOT to use private_html instead of public_html.
Hey there,
After the new update, we are having this "issue"; I'm not sure if it is an issue or if that's the way it is supposed to work.
Every user on our server has to turn on ACME in order to renew the SSL/TLS certificate.
I have checked the global server configuration in Server TLS certificate -> ACME settings, and it is enabled. But I still have to go over every user and enable it manually.
My question is: Is there a way to globally enable ACME for all the users on the server and issue their new SSL certificates?
@rubara Even if UI says the ACME system is disabled the old TLS system will continue to work. This means that after an update even if you do not enable the new TLS system all domains that were using ACME with the old TLS system will continue to work (to renew the certificates).
All domains can be migrated to the new system using the Admin level maintenance task: Admin Tools -> Maintenance -> Enable updated automatic TLS certificates system for all users.
Hi all
I noticed after this update, a background process (maybe tally?) is resetting directory permissions of the log folders /var/log/httpd and /var/log/httpd/domains.
I have scripts in place that need to read files in these folders, a PHP script running under webapps needs to read this folder.
I could run the scripts under apache, but I was wondering if there is another way, it worked for years.
How can I fix this?
Edit: it is logrotate that does this, not DirectAdmin
Edit2: i wrote a patch for the file /usr/local/directadmin/scripts/set_permissions.sh
Kr
Dries
I'm having trouble sorting the email accounts list by the number of sent emails or storage usage.
When I click either column header, a blue progress bar appears, suggesting that the request is being processed. However, the list remains greyed out and never refreshes.
Has anyone encountered this issue or knows how to resolve it?
Thanks in advance!
Mateusz
In the browser console, I get the following error:: Uncaught (in promise) TypeError: n.forEach is not a function - index.Bc28GVbd.js:55:66397
Thanks in advance!
Mateusz
