DirectAdmin 1.712
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.712.
DirectAdmin 1.712​
Note: Automatic DA updates will only start on 2026-10-05 8:00 UTC (Monday).
Will this feature be available in future versions soon? I look forward to using it. Additionally, If "Isolated FPM" not available yet in package conf, I suggest updating the image to avoid confusion for users searching for the 'Isolated FPM user package' .
The isolated-fpm feature has been present in DA for a while now:
https://docs.directadmin.com/webser...user-isolated-php-fpm-for-jailed-environments
It's enabled when you have isolated-fpm=1 in your directadmin.conf, along with jail=1.
Where did you find this screenshot?
Indeed, I haven't found this option and image yet either. How can you enable this via the UI?
Sorry 🤦‍♂️, that option is created with "Custom package items" feature. A leftover on our testing server. The screenshot is cropped, thanks for spotting it.
It does nothing, can be recreated with:
/usr/local/directadmin/data/admin/custom_package_items.conf:1:dummy_isolated_fpm=type=checkbox&checked=yes&string=Isolated+FPM&desc=Use+isolated+PHP-FPM&hidden=no&api_only=no
We have a problem since this release with OpenLiteSpeed, looks like the problem occurs with: openlitespeed-1.9.3. The impacted systems run Debian 12 as OS. After the upgrade, websites will not been served. Browser keeps loading.
I've rebuild OLS and PHP with custombuild, but it will not solve the problem. When I go back to stable release, the problem is solved with: openlitespeed-1.9.2.
Please help us to investigate this, when this update goes from current to stable, we expect much impact on customer servers.
I have a problem updating mod_hostinglimits — it doesn't seem to work correctly.
The update process starts normally, either from the web interface or from the command line, and no obvious errors are displayed. However, after the update finishes, CustomBuild still reports the same version of mod_hostinglimits as available for update.
It looks like the update is either not being applied or CustomBuild is not detecting the installed version correctly.
Has anyone else experienced this issue?
@matkra it is known issue that comes from CloudLinux side and it can be fixed only by them. More details you can find here:
When a domain exists on another cluster server the output text is not entirely correct see > Domain exists on server1113.server1113.com<br> <br> <br>.
