PHP versions 7.3 - 5.6 does not yet have a patch, we wanted to release what we have as soon as possible. Once we have patches for older PHP we will release them.
Wow that would be great! Better than what they do at Plesk!
# da build php 8.0
download_cached: using cached '/usr/local/directadmin/custombuild/cache/php-8.0.22.tar.gz' file
Patching PHP 8.0 ...
patching file ext/openssl/openssl.c
Hunk #1 succeeded at 1313 (offset -12 lines).
patching file ext/intl/config.m4
patching file ext/xml/compat.c
Hunk #1 succeeded at 374 (offset -1 lines).
patching file ext/xml/tests/gh14834.phpt
patching file ext/standard/tests/ghsa-wpj3-hf5j-x4v4.phpt
patching file main/php_variables.c
Hunk #2 FAILED at 119.
Hunk #3 succeeded at 222 (offset -14 lines).
Hunk #4 succeeded at 265 (offset -14 lines).
1 out of 4 hunks FAILED -- saving rejects to file main/php_variables.c.rej
patching file NEWS
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file NEWS.rej
patch_dir_apply: failed to apply '/usr/local/directadmin/custombuild/patches/php-8.0/100-php-cve-2024-2756.patch' patch
install_php: failed to compile '/usr/local/directadmin/custombuild/cache/php-8.0.22.tar.gz' inside '/usr/local/directadmin/custombuild/tmp/tmp.DKAlQ1r4mn.php-8.0.22.tar.gz'
Yes it does...What about Legacy lifetime license does it also get the updates ?
As I see on my AL 9.8 I have PHP 8.0.30 and I can build it without any issues. In your case you still have 8.0.22 one. Please try checking it closer.Some of my server cannot update PHP 8.0. It's error like this. Any ideas to solve the issues?
This is Almalinux 8.0 that we have schedule plan to migrate on Oct 26 but if no workaround I think I will migrate tonight![]()
[root@*redacted*~]# da build php
download_cached: downloading 'https://www.php.net/distributions/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/cache/php-8.2.35.tar.gz'
Warning: Transient problem: timeout Will retry in 1 seconds. 3 retries left.
Warning: Transient problem: timeout Will retry in 2 seconds. 2 retries left.
Warning: Transient problem: timeout Will retry in 4 seconds. 1 retries left. # # #
-=O=- # # # #
curl: (28) Connection timed out after 10000 milliseconds
safe_download: downloading 'https://www.php.net/distributions/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (0/3)
##O=# #
curl: (22) The requested URL returned error: 404
safe_download: downloading 'https://files.directadmin.com/cache/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (0/3)
-=O=- # # # #
curl: (28) Connection timed out after 10001 milliseconds
safe_download: downloading 'https://www.php.net/distributions/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (1/3)
safe_download: downloading 'https://files.directadmin.com/cache/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (1/3)
-=O=- # # # #
safe_download: downloading 'https://www.php.net/distributions/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (2/3)
safe_download: downloading 'https://files.directadmin.com/cache/php-8.2.35.tar.gz' to '/usr/local/directadmin/custombuild/tmp/tmp.NB0kOtwGUr.safe_download' failed (3/3)
Tried several times over the past 1,5 hours. What can be the reason?
# cat versions.txt | grep 'php80'
php80:8.0.30:
php80:8.0.30:
# da build clean
cleaning up temporary build dir '/usr/local/directadmin/custombuild/tmp'
cleaning up download cache dir '/usr/local/directadmin/custombuild/cache'
removed '/usr/local/directadmin/custombuild/cache/php-8.0.22.tar.gz'
# da build update
directadmin current 1.712 d957aed17d065aaa71291aed792cd72158492a01 is already latest
# da build php 8.0
download_cached: downloading 'https://www.php.net/distributions/php-8.0.22.tar.gz' to '/usr/local/directadmin/custombuild/cache/php-8.0.22.tar.gz'
#################################################################################################################################################################### 100.0%
patching file NEWS
install_php: failed to compile '/usr/local/directadmin/custombuild/cache/php-8.0.22.tar.gz' inside '/usr/local/directadmin/custombuild/tmp/tmp.ccBP9jJv9g.php-8.0.22.tar.gz'
php80:8.0.30: => php80:8.0.22:
Why don't you (the ones running older versions) update your code to run under a more modern version? I had to patch some sites but that was, with AI help really easy.
Tell that to the clients that don't want to pay for upgrading their Magento 1.9x CE installation. Some of us are just sysadmins getting paid to keep it running at all costs.
Depends on the virtualization ofcourse. Not always possible and also not always without issues...I don't want to be rude, but seriously, CentOS 7 is so outdated that you could do already an in-place upgrade to Almalinux.
