Preventing malicious traffic from bc.googleusercontent.com
After my last post I wrote a cron script to retrieve and block googleusercontent ip's with CSF/LFD.
Add in /etc/csf/csf.blocklists (or use the CSF web ui)
GOOGLECLOUD|86400|0|https://domain.com/blocklists/bcgoogle-cloud_ips.txt
Use a domain you own or have access to. (If the blocklist isn't loaded afterwards by CSF, then check folder and file permissions)
create /etc/cron.daily/parse_bcgoogle-cloud.py and make it executable.
Contents of file:
#!/usr/bin/env python3
import json
import urllib.request
import subprocess
from pathlib import Path
URL = "https://www.gstatic.com/ipranges/cloud.json"
OUTPUT_PATH = Path(
    "/home/admin/domains/domain.com/public_html/blocklists/bcgoogle-cloud_ips.txt"
HEADERS = {
    "User-Agent": (
        "Mozilla/5.0 (Windows NT 10.0; Win64; x64) "
        "AppleWebKit/537.36 (KHTML, like Gecko) "
        "Chrome/120.0.0.0 Safari/537.36"
try:
    req = urllib.request.Request(URL, headers=HEADERS)
    with urllib.request.urlopen(req, timeout=30) as response:
        data = json.loads(response.read().decode("utf-8"))
    ip_list = []
    for item in data.get("prefixes", []):
        ip = item.get("ipv4Prefix") or item.get("ipv6Prefix")
        if ip:
            ip_list.append(ip)
    # Remove duplicates and sort for consistent output
    ip_list = sorted(set(ip_list))
    new_content = "\n".join(ip_list) + "\n"
    # Read existing content if the file exists
    if OUTPUT_PATH.exists():
        old_content = OUTPUT_PATH.read_text()
    else:
        old_content = ""
    # Only update when something changed
    if new_content != old_content:
        OUTPUT_PATH.write_text(new_content)
        print(
            f"Updated {len(ip_list)} unique Google-cloud IPs/CIDRs "
            f"in {OUTPUT_PATH}"
    else:
        print("No changes detected.")
except subprocess.CalledProcessError as e:
    print(f"Failed to restart CSF/LFD: {e}")
except Exception as e:
    print(f"Error processing IP list: {e}")
Originally I restarted CSF with this script, but realized this was not necessary, because CSF will read the blocklist automatically according to the settings in
So this is leftover code (I left it as is, because I have to test if the script still works without) :
But as lazy as I am, I thought hey my script is working so why spend energy in optimizing as I am not a very good coder. ;) And yes I had help from AI.
After setting this up execute ./parse_bcgoogle-cloud.py and check if https://domain.com/blocklists/bcgoogle-cloud_ips.txt is created, if not check file and folder permissions and execute again.
Then execute csf -ra and check in /var/lib/csf if csf.block.GOOGLECLOUD is created
If you have improvements or suggestions, you're welcome to share.
I have PHP script for you guy without needed the cronjob, also this is AI Code, the script will have self-cache to ".bcgoogle-cloud-cache" directory
<?php
declare(strict_types=1);
 * Google Cloud -> CSF/LFD blocklist. Requires PHP 8.0+ and ext-curl.
 * Upload as /blocklists/bcgoogle-cloud_ips.php.
 * PHP must be able to create/write the cache directory beside this file.
 * A missing cache-directory .htaccess is automatically created on every request
 * with "Require all denied". Apache 2.4 must allow AuthConfig overrides there.
 * Existing .htaccess files are preserved.
 * Both CIDR ranges and plain IPv4/IPv6 values are accepted and emitted as given.
 * /etc/csf/csf.blocklists:
 * GOOGLECLOUD|3600|0|https://domain.com/blocklists/bcgoogle-cloud_ips.php
 * The PHP cache lasts 3600 seconds. Refresh happens on the next request after
 * expiry; no cron is required. The CSF example also uses a 3600-second interval.
 * Failed refreshes preserve and serve the last valid cache, even after expiry.
 * With no valid cache available, failures return HTTP 503.
ini_set('display_errors', '0');
header('Content-Type: text/plain; charset=UTF-8');
header('X-Content-Type-Options: nosniff');
header('Cache-Control: no-store');
$sourceUrl = 'https://www.gstatic.com/ipranges/cloud.json';
$cacheTtl = 3600;
$cacheDirectory = __DIR__ . '/.bcgoogle-cloud-cache';
$cacheFile = $cacheDirectory . '/google-cloud.txt';
function googleCloudPrepareCacheDirectory(string $directory): void
    if (!is_dir($directory) && !@mkdir($directory, 0700, true) && !is_dir($directory)) {
        throw new RuntimeException('Cannot create cache directory: ' . $directory);
    $htaccess = $directory . '/.htaccess';
    if (is_file($htaccess)) {
        return;
    // Exclusive creation preserves a file another request may have just created.
    $handle = @fopen($htaccess, 'x');
    if ($handle === false) {
        clearstatcache(true, $htaccess);
            return;
        throw new RuntimeException('Cannot create cache-directory .htaccess.');
    $complete = false;
    try {
        $rules = "Require all denied\n";
        if (@fwrite($handle, $rules) !== strlen($rules) || !@fflush($handle)) {
            throw new RuntimeException('Cannot write cache-directory .htaccess.');
        $complete = true;
    } finally {
        fclose($handle);
        if (!$complete) {
            @unlink($htaccess);
function googleCloudValidIpOrCidr(string $address, ?int $family = null): bool
    $parts = explode('/', $address);
    if (count($parts) > 2) {
        return false;
    $family = $family ?? (strpos($parts[0], ':') === false ? 4 : 6);
    $flag = $family === 4 ? FILTER_FLAG_IPV4 : FILTER_FLAG_IPV6;
    if (filter_var($parts[0], FILTER_VALIDATE_IP, $flag) === false) {
        return false;
    // A plain IP remains a plain IP in the generated blocklist.
    if (count($parts) === 1) {
        return true;
    // A default route (/0) is deliberately rejected for this blocklist.
    if (preg_match('/\A[1-9][0-9]{0,2}\z/', $parts[1]) !== 1) {
        return false;
    return (int) $parts[1] <= ($family === 4 ? 32 : 128);
function googleCloudReadCache(string $path): ?array
    $handle = @fopen($path, 'rb');
        return null;
    try {
        $stat = fstat($handle);
        $body = stream_get_contents($handle);
    } finally {
        fclose($handle);
    if ($stat === false || $body === false || $body === '') {
        return null;
    foreach (explode("\n", rtrim($body, "\r\n")) as $line) {
        if (!googleCloudValidIpOrCidr(rtrim($line, "\r"))) {
            return null;
    return ['body' => $body, 'time' => (int) $stat['mtime']];
function googleCloudDownload(string $url): string
    if (!extension_loaded('curl')) {
        throw new RuntimeException('The PHP cURL extension is required.');
    $curl = curl_init($url);
    if ($curl === false) {
        throw new RuntimeException('Could not initialize cURL.');
    $body = '';
    try {
        curl_setopt_array($curl, [
            CURLOPT_CONNECTTIMEOUT => 5,
            CURLOPT_TIMEOUT => 20,
            CURLOPT_FOLLOWLOCATION => false,
            CURLOPT_SSL_VERIFYPEER => true,
            CURLOPT_SSL_VERIFYHOST => 2,
            CURLOPT_HTTPHEADER => ['Accept: application/json'],
            CURLOPT_USERAGENT => 'GoogleCloud-CSF-Blocklist/1.0',
            CURLOPT_WRITEFUNCTION => static function ($handle, string $chunk) use (&$body): int {
                $body .= $chunk;
                return strlen($chunk);
        if (curl_exec($curl) === false) {
            throw new RuntimeException('Google feed request failed: ' . curl_error($curl));
        $status = (int) curl_getinfo($curl, CURLINFO_HTTP_CODE);
        if ($status !== 200) {
            throw new RuntimeException('Google feed returned HTTP ' . $status . '.');
    } finally {
        unset($curl);
    $data = json_decode($body, true, 512, JSON_THROW_ON_ERROR);
    if (!is_array($data) || !is_array($data['prefixes'] ?? null) || $data['prefixes'] === []) {
        throw new RuntimeException('Google feed has no valid prefixes array.');
    $addresses = [];
    foreach ($data['prefixes'] as $entry) {
        if (!is_array($entry)) {
            throw new RuntimeException('Google feed contains an invalid prefix entry.');
        $found = false;
        foreach (['ipv4Prefix' => 4, 'ipv6Prefix' => 6] as $key => $family) {
            if (!array_key_exists($key, $entry)) {
                continue;
            $address = $entry[$key];
            if (!is_string($address) || !googleCloudValidIpOrCidr($address, $family)) {
                throw new RuntimeException('Google feed contains an invalid IP address or CIDR.');
            $addresses[$address] = true;
            $found = true;
        if (!$found) {
            throw new RuntimeException('Google feed contains an entry without an IP address or CIDR.');
    $lines = array_keys($addresses);
    sort($lines, SORT_STRING);
    return implode("\n", $lines) . "\n";
function googleCloudWriteCache(string $directory, string $path, string $body): void
    $temp = @tempnam($directory, 'feed-');
    if ($temp === false) {
        throw new RuntimeException('Cannot create a temporary cache file.');
    try {
        $expectedDirectory = realpath($directory);
        if ($expectedDirectory === false || realpath(dirname($temp)) !== $expectedDirectory) {
            throw new RuntimeException('Temporary cache file is outside the cache directory.');
        if (@file_put_contents($temp, $body) !== strlen($body)) {
            throw new RuntimeException('Cannot write the complete cache file.');
        if (!@rename($temp, $path)) {
            throw new RuntimeException('Cannot replace the cache file.');
    } finally {
        if (is_file($temp)) {
            @unlink($temp);
// Protect the directory before both fresh-cache responses and refreshes.
try {
    googleCloudPrepareCacheDirectory($cacheDirectory);
} catch (Throwable $error) {
    error_log('[GoogleCloud blocklist] ' . $error->getMessage());
    http_response_code(503);
    header('Retry-After: 60');
    header('X-Blocklist-Cache: UNAVAILABLE');
    echo "# Google Cloud cache protection is unavailable.\n";
    exit;
$cache = googleCloudReadCache($cacheFile);
$cacheStatus = 'HIT';
$lock = null;
$locked = false;
if ($cache === null || time() - $cache['time'] >= $cacheTtl) {
    try {
        $lock = @fopen($cacheDirectory . '/refresh.lock', 'c');
        if ($lock === false) {
            throw new RuntimeException('Cannot open the cache refresh lock.');
        // Cold requests wait for the first refresh; other requests can serve stale data.
        $locked = flock($lock, $cache === null ? LOCK_EX : LOCK_EX | LOCK_NB);
        if ($locked) {
            // Another request may have refreshed while this request was waiting.
            $cache = googleCloudReadCache($cacheFile) ?? $cache;
                $body = googleCloudDownload($sourceUrl);
                googleCloudWriteCache($cacheDirectory, $cacheFile, $body);
                $cache = ['body' => $body, 'time' => time()];
                $cacheStatus = 'REFRESH';
        } elseif ($cache !== null) {
            $cacheStatus = 'STALE';
        } else {
            throw new RuntimeException('Cannot acquire the cache refresh lock.');
    } finally {
        if (is_resource($lock)) {
            if ($locked) {
                flock($lock, LOCK_UN);
            fclose($lock);
if ($cache === null) {
    echo "# Google Cloud blocklist temporarily unavailable.\n";
    exit;
header('X-Blocklist-Cache: ' . $cacheStatus);
header('X-Blocklist-Cache-Age: ' . max(0, time() - $cache['time']));
echo $cache['body'];
Anecdotally, GCP abuse seems to have died down a bit on my side. I used to see 10+ notifications from CSF a day from the GCP network and I don't recall the last one I saw.
Did they finally get their house in order?
