Kernel TCP (CVE-2026-98432)
nathany
A new Linux kernel vulnerability, CVE-2026-98432, is a use-after-free in the code that sets up incoming IPv4 TCP connections. The Linux kernel CVE team scores it CVSS 9.8 (Critical), with a network attack vector and no privileges or user interaction required.
I can only say that with all the recent CVEs for the Kernel the Debian devs/maintainers have been doing a fantastic job of patching, think every time they have been the first to release by quite a margin. We are heavily Debian based but still have Almalinux and Cloudlinux, makes me think we should be revisiting those.
I wonder what takes so long for Ubuntu then as that is also Debian based (Debian derative).
As far as the rest:
As of October 29, Ubuntu and RHEL have not released a fixed kernel. Red Hat, Amazon, Oracle, and SUSE score the flaw between 5.9 and 8.1, lower than the kernel team's 9.8.
And today, October 31, still nothing at least as far as RHEL goes.
Seems this can be temporarily more or less protected manually until the kernel fix. I read this on Facebook on a security page:
We applied a temporary mitigation on our clients' servers, with no reboot and no downtime. It drops IPv4 TCP packets that carry IP options. The exploit needs these options, and legitimate traffic practically never uses them.
But I don't know if this is correct and also don't know how to do this.
we are safe, it's off by default if your server are installed as clean OS not modify by your provider
$ sysctl net.mptcp.enabled
net.mptcp.enabled = 0
$ sysctl net.ipv4.tcp_migrate_req
net.ipv4.tcp_migrate_req = 0
Debian not safe
# sysctl net.ipv4.tcp_migrate_req
# sysctl net.mptcp.enabled
net.mptcp.enabled = 1
Just as precaution, i apply the follow rule on NFT.
echo 'net.ipv4.tcp_migrate_req = 0' | sudo tee /etc/sysctl.d/99-cve-2026-98432.conf
sysctl --system
sudo nft -f - <<'EOF'
add table ip cve_2026_98432
delete table ip cve_2026_98432
table ip cve_2026_98432 {
    chain prerouting {
        type filter hook prerouting priority -300; policy accept;
        meta l4proto tcp ip hdrlength > 5 counter drop
EOF
Debian not safe
Some folks already reported CVE doesn't need mptcp to be exploited so info isn't accurate. Someone used GLM-5.3 Flash to engineer a POC exploit for this CVE without mptcp requirement.
Does anyone know if on rocky linux 9 this command solves the issue right now?
sudo dnf upgrade kernel
If so. Any gitchas?
If so. Any gitchas?
You can check with sudo dnf check-update to see if there even are kernel updates already, which is not the case.
Once kernel updates will be released you can issue your command to update the kernel, you have to reboot the server afterwards.
If you never updated a kernel before, then I would suggest to do so anyway because there were some past kernels with issues too.
Update: The fix is now in regular kernel updates​
2026-11-02: The CVE-2026-98432 fix is now included in the regular AlmaLinux kernel updates in the production repositories for AlmaLinux 8, 9, and 10. You no longer need to enable the testing repo.
