How can I block this spam coming via Google?
Need ratelimitter from exim.conf, pure spamassassin can't prevent this anymore since it validate/pass rDNS, DKIM, SPF. So the spam score become -15
The one feature that DA still missing, but it's gonna has the problem with big email service like gmail or hotmail, it gonna trigger the ratelimit faster than other mail service.
A ratelimitter won't fix this either because it's not like we are receiving them in a high rate flow, they are several a day and it's very annoying.
Google and Microsoft should just stop using this service or protect things better. Otherwise it's better to block everything coming from gmail which is not from @gmail.com address I think. I just don't know how to do that yet.
Although this would also block a lot of valid domains.
I didn't read the whole thread, but this right here goes in /etc/exim.acl_check_recipient.pre.conf:
# Nice try fuckers
deny    message   = Envelope sender domain not permitted
        !senders  = /etc/exim/firebaseapp_whitelist
        condition = ${if match{$sender_address_domain}{\N(^|\.)firebaseapp\.com$\N}{yes}{no}}
Then you whitelist the exceptions in /etc/exim/firebaseapp_whitelist (touch the file first if you keep the whitelist).
It's hard to stay on top of all of the trends, you can see my whole exim.acl_check_recipient.pre.conf here:
It just keeps growing and growing as trends change. With AI involved now, the chase never ends. That's why I'm working on a hybrid in-house LLM filtering model. Btw don't drop my whole exim.acl_check_recipient.pre.conf into yours, exim won't reload, it has dependencies.
Thank you very much, but I think here is where it would go wrong for me.
I'm no scripter so often I don't really understand these things fully. But doesn't this block everything except what is in the whitelist? Or am I misunderstanding something here?
Would be very hard for me and I also would like to use whitelists to a minimum if possible. To me it's only important that only all mails from gmail.com are also originated from gmail.com and not from some other domain which is sending via gmail.com.
I loved your RBL earlier, unfortunately I had to disable it (also asked by my collegue who pays for the server), because it blocked just a bit too many good addresses.
Very big list you got there, LoL. Looks good. I think I might be able to get some more interesting out of it.
Everything from firebase addresses. Which, frankly, your whitelist is likely to remain empty. No one important sends email from a firebase hostname as the envelope sender.
I'm from an era where you could use telnet to send mail, as anyone, to anywhere. Glorious times! :)
Our best defence at that time was "if it's from there and has d*ck in it, it's spam". And now we're back full circle where spammers simply make sure the hurdles we throw at them are taken and they spam again. And we're again doing "if from there it's spam"... :)
On a lot of servers that is still working. :)
I'm now looking for a "if it's from there, but not created their /except forwardings/ then it's spam". :)
Which is not really true either in several cases but Google should just take better care that these things are not happening.
If they provide the service to pickup mail from other domains, they should make rules stricter and not use their own spf and dkim and such. Or take better countermeasures another way.
Otherwise you're not worth being on the dnsbwl (or what's it called) whitelist.
hello, are you sure you want to blocked all the incoming email that coming from google group but by their customer custom email ?
#/etc/exim.acl_check_message.pre.conf
deny
    hosts = google.com : *.google.com
    !sender_domains = gmail.com : googlemail.com : google.com : googlegroups.com
    message = Rejected: non-Google sender relayed through Google ($sender_address)
    log_message = BLOCK_GOOGLE_RELAY sender=$sender_address host=$sender_host_name ip=$sender_host_address
exim -bV
systemctl restart exim
The example data:
Received: from mail-wm1-x347.google.com ([2a00:1450:4864:20::347])
(envelope-from <[email protected]>)
Google SMTP server       -> YES
sender domain sh4y.de    -> not allowed
                          -> REJECT
this still allowed sender from google itself, but any customize domain will blocked, adjust "$sender_domains" allowed list as you want,
########### spamassassin rules ##########
#/etc/mail/spamassassin/local.cf
header __FROM_GOOGLE_RELAY X-Spam-Relays-External =~ /\brdns=\S*\.google\.com\b/i
header __GOOGLE_ALLOWED_FROM From:addr =~ /\@(gmail\.com|googlemail\.com|google\.com|googlegroups\.com)$/i
meta GOOGLE_RELAY_NON_GOOGLE_FROM (__FROM_GOOGLE_RELAY && !__GOOGLE_ALLOWED_FROM)
describe GOOGLE_RELAY_NON_GOOGLE_FROM Google SMTP relay with non-Google From domain
score GOOGLE_RELAY_NON_GOOGLE_FROM 30.0
NOTE: this is answer coming from chatgpt with provide clear answer and result
Seems spam is arising again via Google SMTP, I've also seem *20260707.gappssmtp.com being used (owned by Google), but I don't get it blocked.
Reporting all via Spamcop to Google also does not seem to have any effect, the spam mails keep coming.
I even had *.ac.in for example in blacklist_domains, still I get mail from that domain via Google. :(
I found this thread after seeing the spam mails from Google accounts increase a lot lately. I've reported a lot of mails via https://support.google.com/mail/contact/abuse but it doesn't seem to help.
I did notice the Message-id lines in the header like:
Message-ID: <[email protected]>
So I've created my own file: /etc/mail/spamassassin/jkws.cf
With the following content:
# Google "autogen" spam
header   JKWS_GOOGLE_AUTOGEN  Message-ID =~ /^<autogen-[a-z]+-[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}\@google\.com>$/i
describe JKWS_GOOGLE_AUTOGEN  Message-ID lijkt op Google autogen-spam
score    JKWS_GOOGLE_AUTOGEN  3.0
After that, execute this:
Bash:
systemctl restart spamassassin
Now let's hope it will help! The score value can be changed (start with a lower score and increase it if it actually only hits the spam).
Indeed. I reported douzens of them via Spamcop but also didn't seem to work.
Until this point I didn't encounter any messages with autogen-java in it, but I will keep an eye open for it.
What I did find was some mailserver from google via which spam originated every time.
That was variousdomains.20260707.gappssmtp.com so I just blocked the gappssmtp.com domain, seems a bit more quiet now. However I'm not sure if valid mails from people using Google as mailserver for their own domains will come through now.
Thanks for your contribution, I will add that one to my spamassassin too just to be sure.
Will SA see that file automatically? Shouldn't we add this to the local.cf then?
