vulnerabilities in the NGINX HTTP/2 implementation
zEitEr
Super Moderator
www.poralix.com
Due to vulnerabilities in the NGINX HTTP/2 implementation (CVE-2026-123007 and CVE-2026-123633), the HTTP/2 support needs to be disabled in Nginx
As a preventive measure HTTP/2 should be disabled in NGINX on all affected servers until the relevant security updates become available. As soon as these updates are released, you can install them and re-enable HTTP/2.
Update 1:
A new version of NGINX is already released, you can force it by the following commands (until DA updated):
Bash:
perl -pi -e "s/nginx:.*\n//" /usr/local/directadmin/custombuild/custom_versions.txt;
sed -i -e 's/^nginx:.*/nginx:1.31.9:/' /usr/local/directadmin/custombuild/versions.txt
da build nginx
Update 2:
DirectAdmin pushed a new version with Nginx 1.31.9 already. In order to secure your server run the following commands as root:
Bash:
da build update
da build nginx
Check and make sure you have updated NIGNX by running the following command as root:
Bash:
nginx -v
expected output:
Bash:
[root@poralix]# nginx -v
nginx version: nginx/1.31.9
[root@poralix]#
2026-11-18nginx-1.30.7 stable and nginx-1.31.9 mainline versions have been released, with vulnerability fixes for use-after-free in resolver (CVE-2026-123634), memory corruption in HTTP/2 flow control (CVE-2026-123007), use-after-free in HTTP/3 (CVE-2026-121810), use-after-free in HTTP/2 (CVE-2026-123633), infinite loop while reading client request body over TLS 1.3 (CVE-2026-118899), use-after-free in mail proxy module (CVE-2026-113425), NULL pointer dereference when using PROXY protocol version 2 (CVE-2026-120993), buffer overflow when using alias with try_files (CVE-2026-125283), SNI bypass in client certificate validation in stream module (CVE-2026-120967), and insufficient validation in stream ssl_preread module (CVE-2026-123640).
There is already a fix, see https://nginx.org/
Asked support to bump the version on latest DA
Then fix (until DA updated):
Bash:
echo nginx:1.31.9: | tee /usr/local/directadmin/custombuild/custom_versions.txt
da build nginx
^^^ The version overwriting in versions.txt or custom_vetsions.txt might still be required on servers with CentOS 7 and old Debian OS. As there is no official update of DirectAdmin with fixed Nginx version.
For temporary version bumping it would be easier to modify the /usr/local/directadmin/custombuild/versions.txt file. That way the modifications are wiped-out on next DA update (which will include the latest version anyway). No need to remember to remove the version locking.
da build nginx
New builds are already released in current and stable. Sorry for confusion. I just mentioned the version.txt as a tip if you need it in less critical situations for temporary version bump.
