DirectAdmin 1.714
hello,
not relate to this version update:
can we have toggle automatics update on this page ? put some button/action next to the "restart" button like in the image that I fast draft it, I expect on future version to have this.
1795024249767-png.20720
hello,
In addition to this checkbox?
I do not see the update yet. Does it take a while to reach a custombuild mirror?
da build update:
directadmin stable 1.713 9401f8e2f670646fbf173991f98af7c348e61b5f is already latest
da build update:
Looks correct to me.
$ dig +short -t txt stable-version.directadmin.com
"v=1.713&commit=9401f8e2f670646fbf173991f98af7c348e61b5f&rt=2026-11-19T14:47:47Z&du=120h&df=12h"
da build update:
You're on the stable version. Switch to the current version for the latest updates.
Is there a plugin or option that shows which PHP version each user is using, without having to check them one by one?
If you using PHP in PHP-FPM mode the information about domain, user and PHP version here (not very readable, but you can see the versions):
https://[HOSTNAME]:2222/evo/custom-httpd
Also you can consider using this Plug-In for PHP versions:
for d in /usr/local/directadmin/data/users/*/php; do f=$(ls -1 "$d" 2>/dev/null | head -n1); [ -n "$f" ] && echo "$(basename "$(dirname "$d")"):$f"; done
Stable channel has the latest PHP versions. We are still working on patches, on PHP 7.3 it clashes with a backported feature 🙁. The alpha channel will get a new build on the usual daily schedule.
Will PHP7.4 and PHP7.2 patched as well?
