Roundcube security updates 1.6.22 and 1.7.7 released
Active8
We just published security updates to the 1.6 LTS and 1.7 versions of Roundcube Webmail.
They both contain fixes for recently reported security vulnerabilities.
See the full changelogs in the release notes on the Github download pages for the updated versions 1.6.22 and 1.7.7.
We strongly recommend to update all productive installations of Roundcube 1.6.x and 1.7.x with this new versions.
WARNING: This is the last 1.6 release. Please, upgrade to 1.7 asap. It will be the only line that receives security fixes in the future.
🙏 Been using/offering Roundcube since around 2009 and love it.Thanks to all involved!
The number of bugfix releases of roundcube is getting ridiculous.
Like in every piece of well used software,,,, be it Roundcube, Apache, PHP etc, etc,. Just what you can expect in a world where AI does your bughunting x times better/faster....
At least they get bugfixed. Now with AI in all products holes are found. I've been using Roundcube for years after Squirrel acted a bit odd.
But most used apps are targeted first. So I expect Squirrel to get it's turn later on.
Let's not compare a programming language or a web server to a simple webmail script, which the AI would probably write in a few hours. The problem with XSS bugs in Roundcube has been going on since at least 2023. Theye are now phasing out 1.6 LTS version because "it's hard for them to patch two branches at once" so maybe 1.7 will finally be fixed for good.
Let's bash Roundcube..:mad:.. With an estimated 53+ million installations. Indeed what a simple webmail script and please let your AI of choice write one so we can scrutinize it, please do...I beg you..... Mind you, installations, not directly visible but still.
Anyway I said "well used" and did not directly compare only put it on the same heap of widely used software.With an estimated 210 million active websites worldwide and and estimated 60/70% running php 50'ish vs 150'ish million does make comparing Roundcube to PHP a lot more to the point....:p And PHP is a massive attack surface because of its sheer ubiquity while webmail is a high-value target because it sits directly in front of sensitive communications, attachments, credentials and account recovery messages etc..
Let's not assume that AI slop wouldn't have any bugs. An AI can also find bugs in code it wrote 5 seconds ago. :)
