DirectAdmin 1.715
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.715.
DirectAdmin 1.715​
Computer says no …
Had to report a bug it says
Thank you for the efforts. Could you kindly let me know how to get old-style list of installed versions and enabled options in CLI?
The following output is no way informative:
# da build versions
All software components are up to date.
I don't even say the new output of the command:
da build options
breaks our scripts....
more or less similar output can be get by:
Bash:
da build options | grep -Ev '^Advanced|^-|Extension|Settings|^$|^Options|da build' | awk '{print $1": "$2}'
but what about installed versions?
"da build versions" should same as "da version", with show the all software versions, even up to date
Its output changed since the new release and no longer prints installed versions. I personally would preferer the old style output with a list of installed versions.
For scrips please use special commands:
da build dump_options
da build dump_versions
The output is deliberately structured for easy parsing (pipe separated values). These commands are available since DirectAdmin 1.648 and are used by the web UI.
Edit: for completness:
da build dump_versions              # current and latest versions
da build dump_options               # contents of options.conf with help texts
da build dump_configure_scripts     # list of ./configure scripts
da build dump_build_software        # lsit of da build {something} commands
da build dump_actions               # list of random da build commands
For software the easiest way to check would be cat /usr/local/directadmin/custombuild/versions.txt. We expected the da build versions output to be mostly used to find out if there are any updates pending.
If there is a need for showing what versions are already installed we could extend the CLI interface.
Based on our experience from tech support - the current software version does not matter that much if we know it is up to date.
We still use the return code of `da build versions` to check if there are updates pending. We don't care about what updates there are, just if we need to update or not. Does this still work or should we use a different command for that?
@ju5t, yes it still works. However we do not really like that it clashes with command error detection (plus it can overflow and return 0 if there are exactly 256 updates pending). The long term plan in the future is to create a helper command that would give you the number of updates available. So that the non 0 return codes could be used exclusively to detect the execution errors.
But we are not changing anything in this release for the exit codes.
The command da build list_removals still does not follow the new style
Another question: when changing php1_release directadmin does not run rewrite_confs any longer? Is it a bug?
But "version" must for display versions, If you want to create that style, just create the new command is better than changed the exists behavior
