I think it's that and that is what I'm worried about. Because I had rate limit issues before with SA too, which caused me to take an account at spamhaus.org and also set this lines in the local.cf of SA:
dns_query_restriction deny bl.score.senderscore.com
dns_query_restriction deny sa-accredit.habeas.com
dns_query_restriction deny sa-trusted.bondedsender.org
I don't want these to be queried anymore so I hope I can block these in rspamd too.
I also didn't say I wanted to abandon rspamd, just set it back to SA now, because I can't work with a broken system on a live server. So back to SA until I can fix the rspamd issues I'm having. I clearly stated "had to roll back
for the moment". I would love to start rspamd again.
About resolving and such.
multi.uribl.com (127.0.0.1 returned) means URIBL is blocking queries from the resolver/IP.
So that is a real issue then correct? How can I fix this, same for Spamhaus which I do have a free key for. I could use Spamhaus in Exim but for some time I'm using the sh.cf and sh_scores.cf files for it in SA.
It's not much use if queries get blocked. Especially since our mail flow is rather low compared to most hosting company's.
As for the resolver, we are running bind as a DNS server on our servers and I don't think it's upstreaming, as far as I know it's also caching DNS server. But some of the domains just not turn up with an A record like for example multi.uribl.com which also shows that 127.0.0.1 is working fine as resolver. At least I don't see any forward, neither is any forwarder specified in the named.conf file:
;; AUTHORITY SECTION:
multi.uribl.com. 5 IN SOA uribl.com. dnsadmin.uribl.com. 1795703164 900 450 604800 5
;; Query time: 266 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Thu Nov 26 15:27:45 CET 2026
;; MSG SIZE rcvd: 117
The fuzzy-a.rspamd.com is giving a correct answer:
;; ANSWER SECTION:
fuzzy-a.rspamd.com. 3600 IN A 80.241.57.6
So some of the errors are clear to me as some subdomains do not have a records like multi.uribl.com and also dwl.dnswl.org which also answers the same as multi.uribl.com so I think that is nothing to worry about indeed.
But seems my issue is not my 127.0.0.1 resolver. Also when doing an nslookup only the 127.0.0.1 resolver is mentioned.
@youstable first of all thank you for your patience and great help.
Before enabling Rspamd again, I would run:
Tried that after I went back to SA last night, but didn't work as the rspamadm binary is removed when going back to SA. I will do that when I will try rspamd again for sure. But as you can see local bind resolver is working fine.
So what I'm worried about are these things:
1.)
DNS query blocked on multi.uribl.com (127.0.0.1 returned), possibly due to high volume
We don't have high volume.
We do have a Hetzner ip and I've read on Github there was an issue with resolving when IPv6 was used from Hetzner. Seems that was fixed, but I remember that I had some kind of issues with Spamassassin using another resolver some way which caused me to add this setting in the local.cf so ipv4 was forced used for queries and then problems seemed to be gone.
dns_server 127.0.0.1
do I need to set this somewhere in rspamd too? I got multiple entry's in the /etc/resolv.conf file with 127.0.0.1 first after the search domain.
Should I put the ipv6 localhost as second in the resolv.conf file?
How can I fix the blocked queries which do not seem to happen in SA or SA is not queirying multi.uribl.com which is also possible (didn't check).
2.) Do I need to worry about the dead monitor status messages?
3.) How to I fix the DNS spoofing messages as it says either DNS spoofing or BL internal issue Can it be internal issues on my config? When I tested last night, there was also no mail coming in or going out but the log kept spewing these. Do I need to put my spamhaus key somewhere?
This is one of the mails that rspamd treated so seems it was working, althou I have my questions about something. Made some new lines to make it more readable.
2026-11-26 01:23:53 #1934928(normal) <8c7249>; task; rspamd_task_write_log: id: <[email protected]>, qid: <1xWNHE-00000008SK8-13sX>, ip: 67.21.148.154,
from: <[email protected]>, (default: F (no action): [-1.11/7.00]
[DMARC_POLICY_ALLOW(-0.50){thatericalper.com;quarantine;},RWL_MAILSPIKE_EXCELLENT(-0.40){67.21.148.154:from;},FORGED_SENDER(0.30){[email protected];
[email protected];},R_SPF_ALLOW(-0.20){+mx;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},R_DKIM_ALIGNED(-0.10){strict;},R_DKIM_ALLOW(-0.10){thatericalper.com:s=mistmail;},
HAS_LIST_UNSUB(-0.01){},ARC_NA(0.00){},ASN(0.00){asn:7311;ipnet:67.21.144.0/20;country:CA;},DKIM_TRACE(0.00){thatericalper.com:+;},
FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){[email protected];[email protected];},HAS_REPLYTO(0.00){[email protected];},
MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},PREVIOUSLY_DELIVERED(0.00){[email protected];},RCPT_COUNT_ONE 0.00)1;},
RCVD_COUNT_THREE(0.00){3;},RCVD_TLS_ALL(0.00){},RCVD_VIA_SMTP_AUTH(0.00){},REDIRECTOR_URL(0.00){twitter.com;}
,REPLYTO_DOM_EQ_FROM_DOM(0.00){},REPLYTO_DOM_NEQ_TO_DOM(0.00){},SURBL_MULTI_FAIL(0.00)
{spamfilter.pssnet.com:server fail;www.thatericalper.com:server fail;open.spotify.com:server fail;},TEXT_WORDS_TRUNCATED(0.00){sampled=1;},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 31221, time: 583.40
0ms, dns req: 61, digest: <731acd6fed2080a98d933717125ac5ed>, rcpts: <[email protected]>, mime_rcpts: <[email protected]>, settings_id: customer_prefs
My question is about this part:
Is this on my side? Because my server resolves both those domains perfectly. So why server fail? Or not on my side so nothing to worry about?
Sorry for the long and extended message, but maybe it's just some small fix to add something somewhere (like my spamhaus key and maybe force dns resolver to 127.0.0.1 or something).
