Server Monitoring Software
Status
Not open for further replies.
keefe007
What's the best server monitoring software?
I have looked at Nagios (Netsaint), but I hear it is really hard to setup. What is everyone else using?
We use Nagios and I don't find it difficult to setup at all. The config files are pretty straight forward and there is a tool that will take nmap's XML output and make a config file from it. That makes setting up a new server pretty easy.
=C=
It's quick and dirty, but works great... I suggest webmin's monitoring module (part of the core distribution).
I have mine set up to monitor all the necessary services, and it pages me if something goes down. Works like a charm.
In one instance, I had a web site with some buggy code that was eating up a bunch of processes in the mysql server, so I made a little shell script to do a manual database call from the server and write it out to a text file. Then, I have webmin set up to check the status of that text file. if the text file doesn't exist, then that would indicate the mysql server is choking. When the text file isn't found, i get a page. We finally stomped out the buggy code in the web site, but I kept this monitor in place for a little added comfort.
It's not flashy, and it's very very basic, but webmin works like a charm for me.
I use Big Brother. It works good for what I need. I don't think that it is being developed anymore. The last entry in CHANGES was 02 Jan 2003.
Now that I see how old this software is and how it isn't being updated or developed anymore, maybe I should start looking for something else.
Anyways, it's worked great and I really haven't had a need to check for a more updated version.
Nagios, while not the easiest install in the world (we've been quoted thousands of dollars for the install, but now we do it ourselves and charge significantly less :) ), is free, even for commercial use (Big Brother is not free for commercial use), and IS updated regularly.
SolarWinds SAM
Try using SolarWinds SAM it has a bunch a lot of features, It can also handle Nagios script
http://www.solarwinds.com/application-server-management-software.aspx
I do use Nagios since years and it work pretty nice, not that hard setup and pretty easy to customize with plugins for mysql/most "cute" web interface.
@Jeff: I did ask much less than thousands of dollars ;), but probably someone else did, im happy that you was able to manage installation by yourself :)
Regards
Nope; it wasn't you or anyone else here on these forums. This is a very old thread; my guess is that eramasz is an automated bot. Maybe not, and though it is a commercial product, knowing about it may be important to some of our visitors.
Unified Monitoring Tool
Hello
I have been using Pandora FMS to monitor both network devices and servers and based upon the amount of things you need to monitor it is probably one of the most user friendly tools out there. For more information on Pandora FMS visit the following webpage: http://pandorafms.com/
Regards
Ramon Pulido
Status
