Perfect Partition?
neorder
This is recommanded partition table taken from DA website:
/boot 40 meg
swap 2 x memory
/tmp 1 Gig. Highly recommended to mount /tmp with noexec,nosuid in /etc/fstab
/ 6-10 Gig
/var 8-20 gig. Emails, logs and databases stored here
/usr 5-12 gig. Just DA data, source code, frontpage.
/home rest of drive. Roughly 80% for user data.
I have 3 harddisk now.
SDA: 74G Raptor.
SDB: Barrcuda ES 320G Seagate
SDC: Barrcuda 9 160G
My plan:
since raptor run faster and more like SCSI drive, so i run mysql and email on this harddisk.
/dev/SDA1 = /boot = 250M
Swap on SDA = 2G
/dev/SDA2 = /tmp = 1G
/dev/SDA3 = / = 6G
/dev/SDA4 = /var = Rest of Drive SDA
/dev/SDA5 = /usr = 5G
I plan to have users will use much space, so
/dev/SDB1 = /home = 320G ES Seagate.
Last backup drive
/dev/SDC1 = /backup = 160G
I have a few questiones:
1. what are the things under "/ 6-10 Gig" why do i need to give 6 to 10G here?
2. Is 160G backup drive big enough? how much data can i backup?
3. I run swap and sql, email on Raptor HDD, will it improve overall performance?
4. That's the best redundant HDD setup i can think of. what else i can improve? or do you have better suggestion based on my three Harddisks?
Thanks.
You don't. We set up between 1G and 2G depending on how much we may save in /root. Usually 1G is more than sufficient.
While most of us would expect our backups to compress to half the size of what's being backed up, we generally count on only a 1:1 ratio, as so many files stored on the server these days are already compressed multimedia files.
Probably not that noticeably.
I don't tell people how to partition drives; it often becomes a religious argument. I do recommend you forgo the /boot partition unless you have a real need for it; modern OS distributions don't need it.
Thanks.[/QUOTE]
