RoundCube
DirectAdmin Support
Administrator
Staff member
For anyone interested, Martynas Bendorius has created us a roundcube install script. It's very quick and painless. It's being released as beta, so if there are any issues, please direct them to this thread and not our support email address.
To install it:
wget -O roundcube.sh http://files.directadmin.com/services/all/roundcube.sh
chmod 755 roundcube.sh
./roundcube.sh
Once installed, you'll need to restart apache for the /roundcube alias to function. Note that roundcube uses mysql for it's data, so a da_roundcube database is created.
HI,
To install it:
./roundcube.sh
Very nice only got a error
[root@web02 ~]# cd /usr/local/directadmin/scripts
[root@web02 scripts]# wget -O roundcube.sh http://files.directadmin.com/services/all/roundcube.sh
--00:38:12-- http://files.directadmin.com/services/all/roundcube.sh
=> `roundcube.sh'
Resolving files.directadmin.com... 199.237.54.170
Connecting to files.directadmin.com|199.237.54.170|:80... connected.
Length: 4,617 (4.5K) [application/x-sh]
100%[=================================================================================>] 4,617 --.--K/s
00:38:13 (34.19 KB/s) - `roundcube.sh' saved [4617/4617]
[root@web02 scripts]# chmod 755 roundcube.sh
[root@web02 scripts]# ./roundcube.sh
: bad interpreter: No such file or directory
and now?
I think he saved the file in windows format.. it has to be resaved in linux.. I'll try and mash it back into shape.
Ok, give it another try.
Couple notes for freebsd 6.2, on lines 88, 89, 98 and 99 where it says
/bin/mv --force [files]
you need to change it to
/bin/mv -f [files]
or it will error saying
mv: illegal option -- -
Also mine had the weirdest thing, it had no da_admin or root password set for mysql so if you get permission errors about mysql, try running
/usr/local/bin/mysqladmin -u root password 'new password'
then
/usr/local/directadmin/scripts/mysql.sh 'root mysql password' da_admin 'da_admin password you want'
After that I ran the roundcube.sh script and it worked beautifully.
Instalation in Debian 3.1 went without errors, but keep getting "Login Failed" when trying to use it.
Any ideas ?
I guess that the error is: IMAP Error: Could not connect to localhost at port 143 :)
If you want to see errors - edit /var/www/html/roundcube/config/main.inc.php and set debug level to 4.
Thanks for that tip,
Now in debug mode 4 :
IMAP Error: Authentication for [email protected] failed (LOGIN): "a001 NO LOGIN failed"
Any ideas?
I see that my problem is not related to your install script. Sorry about this folks. Wasn't my intention.
I was sure roundcube will meet the success. I'm happy that DA staff start to support roundcube, one of the largest french ISP also started to beta-test it for the whole portfolio of customers -> http://imp.free.fr/rc/
Thanks Martynas.
Glad to see this script as many of our dedicated server clients have been demanding RoundCube and sometimes have difficulty doing it the long way. This will certainly help them install it more easily and help us with less support requests concerning RoundCube installation. It's scripts like these that make DirectAdmin and its community #1 in our book!
Is RoundCube pure imap? Will it work interchangeably with IMAP mailboxes created with SquirrelMail?
Yes, it's imap.. it should work with existing folders just like squirrelmail. You may need to tell RC to subscribe to the SM folders though.
Anyone that has any respect for their customers will wait until this comes out of beta.... a quick browse of the roundcube forums will show you and abundance of problems from bugs to security holes. I have been following the roundcube project for a little over a year now. It is a very slow moving project and I dont expect it to be out of beta for another year or so.
How do users access RC from their control panels? I dont see a menu option being added for all the themes only an alias outside of the control panel.
