New DA user needs help please.
smoked1
I just got myself a new dedicated server with DA installed on it. I have always done things from the command line and I have never used a Control Panel as an administrator before. I decided to use it this time because I thought that it would make it easier for me to manage my sites.
Where do I start with DA? I need to add my sites. Do I create a reseller and then add them from that account? Someone please point me in the right direction.
You are headed in the right direction, login as the admin for the box via the control panel. Goto the reseller link on the right side of the page. Once there, create a couple of plans, and then you can start adding your customers accounts.
Also see:http://site-helper.com/ which is a good help resource on how to do things in DA via the control panel.
If you are doing it for your own domains then you can add them under the admin User Level without creating any extra packages or users.
