oot@vps [/usr/local/els]# ./els.sh --vps
./els.sh: line 1: { print $1 }: command not found
./els.sh: line 1: { print $2 }: command not found
expr: syntax error
./els.sh: line 1: { print $1, $2, $3, $7 }: command not found
./els.sh: line 1: { print $1, $3 }: command not found
./els.sh: line 1: { print $1, $2 }: command not found
./els.sh: line 1: { print $1, $2, $5 }: command not found
Admin (your) E-Mail Address (this should NOT be on this server):
[email protected]
You entered:
[email protected]
Ensure this is correct.
Proceed? (y/n): y
Using
[email protected].
Several packages installed by yum may not be compatable or may cause
problems with DirectAdmin or cPanel.  To help prevent complications, ELS can add special
packages to be skipped when running yum.
These packages can still be updated manually with yum.
Proceed? (y/n): y
Substitution replacement not terminated at -e line 1.
Done.
./els.sh: line 397: [: !=: unary operator expected
________________________________________________
root@vps [/usr/local/els]# ./updater.sh
./updater.sh: line 1: { print $1 }: command not found
./updater.sh: line 1: { print $2 }: command not found
expr: syntax error
ELS 2.1.0.6 is the latest release, there is no need to update.
