Problem bringing over a MySQL database...
beansbaxter
WA
Under DirectAdmin v1.28.1... under the MySQL backend, I select a database from the drop-down menu, and then browse to find a database to upload it into (a .gz file) and click the Upload button, and then get the following error code:
Unable to restore database scspo2_gallery2 : ERROR 1045 (28000): Access denied for user 'scspo2'@'localhost' (using password: YES) gunzip: stdout: Broken pipe
Not sure why this is happening. Some more info, if it matters...
The MySQL database is being exported from a different server, which is running the following versions:
cPanel Build 10.9.0-RELEASE 118
phpMyAdmin - 2.9.0.2
MySQL 4.0.27-standard
And the server I am trying to upload the database into, the username, database name, and passwords were setup identical to the incoming database I was trying to upload into it.
When looking at the DirectAdmin server info, I noticed it i running
MySQL 4.1.11
phpMyAdmin - 2.8.1
So the MySQL is newer and the phpMyAdmin is older on the current flavor of DirectAdmin...
How can I get a MySQL database from this cPanel to my DirectAdmin????
Thanks in advance?
MySQL 4.1.11
phpMyAdmin - 2.8.1
Thanks in advance?
try to export a SQL dump from phpmyadmin (cPanel) and import it directly in phpmyadmin (DA).
