Hey all,
I would like to uninstall and then reinstall Direct Admin because I upgraded to PHP 5 and it broke a few things
I have looked at: http://www.directadmin.com/forum/showthread.php?t=3365 and am trying to convert it to my servers way of doing so. I am using Debian.
1) Remove all users through DA.
2) Remove the /etc/cron.d/directadmin_cron file
3) rm -rf /usr/local/directadmin
4) Do a dpkg --list to get a list of the installed programs.
5) Find the main services installed by DA (how do I know which ones are installed by Direct Admin?) and then use dpkg --purge to remove them.
6) Apache and PHP are installed from source, so removing them would have to be done manually. (How would one do so?) would i just need to do this:
a) remove apache: "remove httpd"
b) remove php: "dpkg --purge php-4.4.6"
Would I need to remove the other PHP versions installed as well?
Any help is much appreciated.
