edit2:
not goodCode:Configuring SAPI modules checking for AOLserver support... no checking for Apache 1.x module support via DSO through APXS... no checking for Apache 1.x module support... no checking for mod_charset compatibility option... no checking for Apache 2.0 filter-module support via DSO through APXS... no checking for Apache 2.0 handler-module support via DSO through APXS... Sorry, I cannot run apxs. Possible reasons follow: 1. Perl is not installed 2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs 3. Apache was not built using --enable-so (the apxs usage page is displayed) The output of /usr/sbin/apxs follows: /usr/sbin/httpd: error while loading shared libraries: libaprutil-1.so.0: cannot open shared object file: No such file or directory apxs:Error: Sorry, no shared object support for Apache. apxs:Error: available under your platform. Make sure. apxs:Error: the Apache module mod_so is compiled into. apxs:Error: your server binary `/usr/sbin/httpd'.. configure: error: Aborting *** There was an error while trying to configure php. Check the configure/ap2/configure.php4 file
trying it with these options:
Code:default_php=4 php4_cli=yes php4_cgi=no php5_cli=no php5_cgi=yes apache_ver=2.2
What's the output of:
	ldd /usr/sbin/httpd | grep libaprutil
