Server Firewall Error
miltongoh
Singapore
The moment I enable IPTABLES, my DNS seems to screwed up and not working while if I disable it, all website DNS is working fine.
Anything I should do to enable it running well?
What firewall rules are enabled when starting iptables?
Is this wrong?
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 22 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 80 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 21 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 25 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 42 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 53 -j ACCEPT
Have I missed out something?
Are there any OUTPUT rules or is is it set to allow all OUTPUT traffic?
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 2222 -j ACCEPT
This added.
The full file is.
# Firewall configuration written by system-config-securitylevel
# Manual customization of this file is not recommended.
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:RH-Firewall-1-INPUT - [0:0]
-A INPUT -j RH-Firewall-1-INPUT
-A FORWARD -j RH-Firewall-1-INPUT
-A RH-Firewall-1-INPUT -i lo -j ACCEPT
-A RH-Firewall-1-INPUT -p icmp --icmp-type any -j ACCEPT
-A RH-Firewall-1-INPUT -p 50 -j ACCEPT
-A RH-Firewall-1-INPUT -p 51 -j ACCEPT
-A RH-Firewall-1-INPUT -p udp --dport 5353 -d 224.0.0.251 -j ACCEPT
-A RH-Firewall-1-INPUT -p udp -m udp --dport 631 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 8080 -j ACCEPT
-A RH-Firewall-1-INPUT -j REJECT --reject-with icmp-host-prohibited
COMMIT
Does this seems to be a problem? I can't find my DNS working after getting IPTABLES up running. :(
For DNS port 53 needs to be open for both inbound and outbound, for both udp and tcp/ip traffic.
Search these forums for the kiss firewall; it's a simple to install script that will manage iptables for you.
Hi Jeff,
Thanks for the pointer!
Also APF Firewall w/BFD is quite simple to install and will configure iptables for you.
