Php Safe Mode On or Off?
seachen
any expert here can recommend me to switch on or switch of Php Safe Mode?
what is the different between on or off?
thank you.
"on" is better for security, because it doesn't let some exploits to work. If you run PHP as CGI - there is no need to set it on.
Can i pick your brain on this one...
- Will running PHP as CGI have any negative effect?
- Are there any things to be careful of with running PHP as CGI?
- Will php running as cgi still work exactly the same as normal? i.e. wont affect dynamic sites such as forums,blogs, cms's etc.
- Can you point me to how to change php to run as cgi?
I ask as I generally have safe mode "on" on all domains as default, but someone is asking me about vBlogetin and that it wont work on Safe Mode [without some fiddling of things I havent yet learnt or understood lol] so if i could elliminate the need for using Safe Mode, then all the better I guess :)
Cheers
Nath.
