recompile modules in php
Oddis
Hi.
I try to recompile php and according to Directadmin support I shall use:
./build php_ap2 d
(my system is CentOS 3.8)
When I do this, I got this error message:
Done. Making gd-2.0.34...
Trying to make gd...
cd . && /bin/sh /usr/local/directadmin/customapache/gd-2.0.34/config/missing --run autoheader
configure.ac:28: error: Autoconf version 2.58 or higher is required
aclocal.m4:7856: AM_INIT_AUTOMAKE is expanded from...
configure.ac:28: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
autoheader: /usr/bin/autom4te failed with exit status: 1
The latest Autoconf for CentOS v3.8 is 2.57.3
Thanks for any help........
Thanks for your reply.
I have already tried that, but no help
since the latest version for CentOs 3.8 is 2.57.3.
Yum only tells that it is nothing to update
I have the same issue using centos 3 latest build.
Trying to update to the latest version of GD:
make: *** [config.hin] Error 1
Jon
cd /usr/src
wget http://ftp.gnu.org/gnu/autoconf/autoconf-2.61.tar.gz
tar xzf autoconf-2.61.tar.gz
cd autoconf-2.61
./configure --prefix=/usr
make
make install
Then you can do "./build gd".
It works.
Thanks a lot for taking time to explain smtalk....
