floyd
- Mar 29, 2005
I have given the CNAME record as told. I will map the public IP to it and will update you how it goes. Thank you so much.
You can't map an ip to a CNAME
then your record should be like this
*.mojaloop CNAME mojaloop.appliedpaymentstech.com
Not like this
*.mojaloop.appliedpaymentstech.com CNAME mojaloop.appliedpaymentstech.com
this is just call your domain like " http://ANY.mojaloop.appliedpaymentstech.com.mojaloop.appliedpaymentstech.com "
I told you just use cloudflare to confirm your correct records.
Ok so my initial configuration was correct right? I will do the same again and will map the public IP to it. I will update you after that. ThanksThe 2 images you posted in your second post are absolutely correct. Just do that but use the correct ip.
