Hello
The server is too busy. If I add 1 more lan cable it will speed up the access time or not. The server is:
The HP Support told me that I have to use a command that he is not sure. It should be
Please give more usage of which command I should use to make the server can use both 2 Gigb. Ports together.
Thanks & Best Regards
HP Prolian DL 185 G5 - 2 Quadcore Opteron CPU - 4 GB ECC Ram - GB. Lan Port
.TRIM OR BIND PORT
