Done that, still not working
login as: root
[email protected]'s password:
Last failed login: Thu Aug 4 16:40:10 EEST 2022 from 209.141.57.23 on ssh:notty
There were 5 failed login attempts since the last successful login.
Last login: Thu Aug 4 15:54:35 2022 from 5.2.136.14
[root@server-82-78-165-202 ~]# yum remove nftables
Dependencies resolved.
Package Arch Version Repository Size
Removing:
nftables x86_64 1:0.9.3-25.el8 @anaconda 826 k
Removing dependent packages:
firewalld noarch 0.9.3-13.el8 @anaconda 2.0 M
Removing unused dependencies:
firewalld-filesystem noarch 0.9.3-13.el8 @anaconda 239
ipset x86_64 7.1-1.el8 @anaconda 63 k
ipset-libs x86_64 7.1-1.el8 @anaconda 217 k
iptables x86_64 1.8.4-22.el8 @anaconda 1.9 M
iptables-ebtables x86_64 1.8.4-22.el8 @anaconda 14 k
iptables-libs x86_64 1.8.4-22.el8 @anaconda 198 k
libibverbs x86_64 37.2-1.el8 @anaconda 990 k
libnetfilter_conntrack x86_64 1.0.6-5.el8 @anaconda 161 k
libnfnetlink x86_64 1.0.1-13.el8 @anaconda 51 k
libnftnl x86_64 1.1.5-5.el8 @anaconda 217 k
libpcap x86_64 14:1.9.1-5.el8 @anaconda 376 k
python3-decorator noarch 4.2.1-2.el8 @anaconda 47 k
python3-firewall noarch 0.9.3-13.el8 @anaconda 2.0 M
python3-libselinux x86_64 2.9-5.el8 @anaconda 771 k
python3-nftables x86_64 1:0.9.3-25.el8 @anaconda 28 k
python3-slip noarch 0.6.4-11.el8 @anaconda 60 k
python3-slip-dbus noarch 0.6.4-11.el8 @anaconda 70 k
Transaction Summary
Remove 19 Packages
Freed space: 9.9 M
Is this ok [y/N]: y
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Running scriptlet: firewalld-0.9.3-13.el8.noarch 1/1
Running scriptlet: firewalld-0.9.3-13.el8.noarch 1/19
Erasing : firewalld-0.9.3-13.el8.noarch 1/19
Erasing : python3-firewall-0.9.3-13.el8.noarch 2/19
Running scriptlet: ipset-7.1-1.el8.x86_64 3/19
Current iptables configuration requires ipsets
error: %preun(ipset-7.1-1.el8.x86_64) scriptlet failed, exit status 1
Error in PREUN scriptlet in rpm package ipset
Erasing : python3-slip-dbus-0.6.4-11.el8.noarch 4/19
error: ipset-7.1-1.el8.x86_64: erase failed
Erasing : python3-slip-0.6.4-11.el8.noarch 5/19
Erasing : python3-nftables-1:0.9.3-25.el8.x86_64 6/19
Running scriptlet: iptables-ebtables-1.8.4-22.el8.x86_64 7/19
Erasing : iptables-ebtables-1.8.4-22.el8.x86_64 7/19
Erasing : python3-decorator-4.2.1-2.el8.noarch 8/19
Erasing : firewalld-filesystem-0.9.3-13.el8.noarch 9/19
Erasing : iptables-1.8.4-22.el8.x86_64 10/19
Running scriptlet: iptables-1.8.4-22.el8.x86_64 10/19
Running scriptlet: nftables-1:0.9.3-25.el8.x86_64 11/19
Erasing : nftables-1:0.9.3-25.el8.x86_64 11/19
Erasing : iptables-libs-1.8.4-22.el8.x86_64 12/19
Erasing : libpcap-14:1.9.1-5.el8.x86_64 13/19
Erasing : libnetfilter_conntrack-1.0.6-5.el8.x86_64 14/19
Running scriptlet: libnetfilter_conntrack-1.0.6-5.el8.x86_64 14/19
Erasing : libnfnetlink-1.0.1-13.el8.x86_64 15/19
Running scriptlet: libnfnetlink-1.0.1-13.el8.x86_64 15/19
Erasing : libibverbs-37.2-1.el8.x86_64 16/19
Running scriptlet: libibverbs-37.2-1.el8.x86_64 16/19
Erasing : libnftnl-1.1.5-5.el8.x86_64 17/19
Running scriptlet: libnftnl-1.1.5-5.el8.x86_64 17/19
Erasing : python3-libselinux-2.9-5.el8.x86_64 18/19
Erasing : ipset-libs-7.1-1.el8.x86_64 19/19
Running scriptlet: ipset-libs-7.1-1.el8.x86_64 19/19
Verifying : firewalld-0.9.3-13.el8.noarch 1/19
Verifying : firewalld-filesystem-0.9.3-13.el8.noarch 2/19
Verifying : ipset-7.1-1.el8.x86_64 3/19
Verifying : ipset-libs-7.1-1.el8.x86_64 4/19
Verifying : iptables-1.8.4-22.el8.x86_64 5/19
Verifying : iptables-ebtables-1.8.4-22.el8.x86_64 6/19
Verifying : iptables-libs-1.8.4-22.el8.x86_64 7/19
Verifying : libibverbs-37.2-1.el8.x86_64 8/19
Verifying : libnetfilter_conntrack-1.0.6-5.el8.x86_64 9/19
Verifying : libnfnetlink-1.0.1-13.el8.x86_64 10/19
Verifying : libnftnl-1.1.5-5.el8.x86_64 11/19
Verifying : libpcap-14:1.9.1-5.el8.x86_64 12/19
Verifying : nftables-1:0.9.3-25.el8.x86_64 13/19
Verifying : python3-decorator-4.2.1-2.el8.noarch 14/19
Verifying : python3-firewall-0.9.3-13.el8.noarch 15/19
Verifying : python3-libselinux-2.9-5.el8.x86_64 16/19
Verifying : python3-nftables-1:0.9.3-25.el8.x86_64 17/19
Verifying : python3-slip-0.6.4-11.el8.noarch 18/19
Verifying : python3-slip-dbus-0.6.4-11.el8.noarch 19/19
Removed:
Failed:
Error: Transaction failed
