block top level domain
torment
i want block top level domains like *.date or *.loan , i have added this in blacklist_* , but thats not helped me.
i have try with system_filter.exim this was negative too.
.date
.loan
*.date
*.loan
Please any advise ?
Erulezz
Arnhem, NL
To block incoming emails from TLD for a specific user go to:
User Level -> SpamAssassin -> E-mail blacklist
Enter one per line:
*@*.loan
*@*.date
This is for specific users, I don't know exactly how to block these system wide.
ditto
To block them globally add it to /etc/virtual/blacklist_domains - for example add:
*.date
It works for me.
Richard G
Maastricht
The way ditto says is indeed the easiest and works fine. Next to that in contrary to exim.pl it won't be overwritten by an update.
I've got those in there too, works fine indeed:
*.date
*.loan
*.website
torment
i have added like this and make this but nothing change :(
.date
.loan
*.date
*.loan
*@*.loan
*@*.date
torment
off course i have restart exim , what i make :
.date
.loan
*.date
*.loan
*@*.loan
*@*.date
add this line to exim.pl link
if ($username eq "userwithrudomain") { return 1; }
after 2 days %80 blocked .date spam mails.
zEitEr
Super Moderator
GMT +7.00
There is no need to use it at all. It was an example with a fake username:
and here
userwithrudomain should be replaced by a real username for which you want to block SMTP.
torment
and here
i have add this line for example, really look like this;
if ($username eq "*.date") { return 1; }
if ($username eq ".date") { return 1; }
zEitEr
Super Moderator
GMT +7.00
Do you really have hosting users on your server with names "*.date" and/or ".date"? Username and domain name are different words, and they have different meanings.
The file /etc/virtual/blacklist_domains is what you need to use, if the things do not work as they should make sure you've got the latest exim.conf 4.5x and the file /etc/virtual/blacklist_domains has the correct permissions:
[/COLOR]-r--r-----. 1 mail mail 27 Jun 18  2017 /etc/virtual/blacklist_domains
if still emails are not blocked, then you need to check email headers, as they might have different domain in "envelope-from" and "from" headers. Exim tests matches against sender's domain, and sender addresses are easily, and commonly, forged.
Exim on Directadmin servers is configured to use nwildlsearch to find matches in /etc/virtual/blacklist_domains. It means each key in the file may be wildcarded domain. The file should contain domains, not email addresses, i.e. lines without @ should be used.
zEitEr
Super Moderator
GMT +7.00
*.date
It works for me.
I'm not sure what I did wrong this way it did not work for me. Is still working for you under exim.conf 4.5? In my case emails are not blocked if their `from` header contains an address with domain.date
The files
* /etc/virtual/blacklist_domains
* /etc/virtual/blacklist_senders
does not work with masks:
*@*.date
*.date
in my case.
Richard G
Maastricht
Well I'm very confused now.
Jeff also wrote in the past that Wildcards wouldn't work.
But in another thread of my I had the same problem and Directadmin Support wrote that I had to use wildcards?
https://forum.directadmin.com/showthread.php?t=55306&p=283397#post283397
I pointed out the answer which Jeff gave and this is what DA support answered to that:
The exim.conf versions have come a long way; they now support wildcards in certain areas. Just check the exim.conf to see if the load of the file in question is nwildsearch or something containing "wild".
I had them for a long time, I thought they were working.
ditto
Without studying the log files, I can't say for sure. But I _think_ wildcard on top level domains (*.date) in /etc/virtual/blacklist_domains still works for me, as I have not seen any spam from the top level domains that I have blocked. I am running exim.conf 4.5.12
Richard G
Maastricht
I don't want to give the impression that I don't believe people. I can't test it very good myself. It seems to work.
I just want to say that if it does not work, then according to the reply's of DA staff, it must be a bug or something.
solokazama
Sorry for answering old thread but wanted to block top level domain and wildcards worked:
blocked domain (its a free spam domain): *.ICU
2019-04-22 15:00:59 H=archivist.arkeolojimsi.com (archivist.jansewasociety.icu) [185.149.235.12] F=<jadwigaqdphfddflis@jansewasociety.icu> rejected RCPT <xxx@xxxxxxx>: 554 denied. 5.7.1 Domain Blocked due to SPAM
in:
added line (it has more lines of course):
*.icu
all seems to work fine
DA version 1.51.3
