Brute Force Monitor not working with pureftpd.log and phpmyadmin.log
smtalk
Administrator
Staff member
LT, EU
I already use this command before I just forgot to remove "=" .
Now I am getting this:
/usr/local/directadmin# /usr/local/directadmin/directadmin set brute_force_pureftpd_log /var/log/pureftpd.log
Error with the current values:
Cannot find 'brute_force_pureftpd_log' in the directadmin.conf
After update directadmin.conf manually.
brute_force_pureftpd_log=/var/log/pureftpd.log in directadmin.conf but still get the same error with the directadmin set command.
I think you did not update to pre-release, thus option is not there.
crenet
Sorry Martynas but I do update to last DA version, how do I "update to pre-release" ?
DirectAdmin Support
Administrator
Staff member
To clarify, you need only grab the latest DA binaries. Everything's already set inside.
No need to alter the directadmin.conf, as it should (internally) be set to the correct pure-ftpd.log, which is a 2nd scan, in addition to the default /var/log/messages.
crenet
I assume that the last DA binaries should be the pre-release DA version as Martynas said.
