sky
- Nov 12, 2004
Hello
I have switched for the moment back to one php version (5.4)
Everything is now installed.
I have a problem with apache not starting because of this error
Its like Directadmin does not have all files ?
Any ideas ?Installing configuration files
[PRESERVING EXISTING HTDOCS SUBDIR: /var/www/htdocs]
[PRESERVING EXISTING ERROR SUBDIR: /var/www/error]
[PRESERVING EXISTING ICONS SUBDIR: /var/www/icons]
[PRESERVING EXISTING CGI SUBDIR: /var/www/cgi-bin]
Installing header files
Installing build system files
Installing man pages and online manual
make[1]: Leaving directory `/usr/local/directadmin/custombuild/httpd-2.4.2'
Restoring certificate and key, and turning on httpd for DirectAdmins's check.
grep: /usr/local/directadmin/conf/directadmin.conf: No such file or directory
./build: line 7376: [: : integer expression expected
./build: line 7380: [: : integer expression expected
Unable to read config file. Check the file permissionsUnable to read config file. Check to make sure that /usr/local/directadmin/conf/directadmin.conf.lock doesn't exist
Using 178.33.224.187 for your server IP
ls: cannot access /usr/local/directadmin/data/users/*/httpd.conf: No such file or directory
Restarting apache.
Stopping httpd: [FAILED]
Starting httpd: httpd: Syntax error on line 108 of /etc/httpd/conf/httpd.conf: Syntax error on line 21 of /etc/httpd/conf/extra/httpd-vhosts.conf: Could not open configuration file /etc/httpd/conf/ips.conf: No such file or directory
