No i don't have.
This is the complete list with library installed :
AnyDBM_File Apache Apache::Connection
Apache::Constants Apache::Constants::Exports Apache:
ebug
Apache::ExtUtils Apache::FakeRequest Apache::File
Apache::Include Apache::Leak Apache::Log
Apache::ModuleConfig Apache::MyConfig Apache::Opcode
Apache::Options Apache:
erlRun Apache:
erlRunXS
Apache:
erlSections Apache::RedirectLogFix Apache::Registry
Apache::RegistryBB Apache::RegistryLoader Apache::RegistryNG
Apache::Resource Apache::SIG Apache::Server
Apache::SizeLimit Apache::StatINC Apache::Status
Apache::Symbol Apache::Symdump Apache::Table
Apache::URI Apache::Util Apache::httpd_conf
Apache::src Apache::test Attribute::Handlers
AutoLoader AutoSplit B
B::Asmdata B::Assembler B::Bblock
B::Bytecode B::C::Section B::CC
B::Concise B:
ebug B:
eparse
B:
isassembler::BytecodeStream B::Lint B::Showlex
B::Stackobj B::Stash B::Terse
B::Xref Benchmark Bundle::Apache
ByteLoader CPAN CPAN::Mirrored::By
CPAN::Nox Carp Class::ISA
Class::Struct Config Cwd
DB Data:
umper Demo
Descriptions Devel:
Prof Devel:
PPort
Devel:
eek Devel::SelfStubber Digest
Digest::MD5 DirHandle Dumpvalue
DynaLoader Encode Encode::Alias
Encode::Byte Encode::CJKConstants Encode::CN
Encode::CN::HZ Encode::Config Encode::EBCDIC
Encode::Encoder Encode::Encoding Encode::Guess
Encode::JP Encode::JP::H2Z Encode::JP::JIS7
Encode::KR Encode::KR::2022_KR Encode::MIME::Header
Encode::Symbol Encode::TW Encode::Unicode
English Env Errno
Exporter Exporter::Heavy ExtUtils::Command
ExtUtils::Command::MM ExtUtils::Constant ExtUtils::Embed
ExtUtils::Install ExtUtils::Installed ExtUtils::Liblist
ExtUtils::Liblist::Kid ExtUtils::MM ExtUtils::MM_Any
ExtUtils::MM_BeOS ExtUtils::MM_Cygwin ExtUtils::MM_DOS
ExtUtils::MM_MacOS ExtUtils::MM_NW5 ExtUtils::MM_OS2
ExtUtils::MM_UWIN ExtUtils::MM_Unix ExtUtils::MM_VMS
ExtUtils::MM_Win32 ExtUtils::MM_Win95 ExtUtils::MY
ExtUtils::MakeMaker ExtUtils::Manifest ExtUtils::Miniperl
ExtUtils::Mkbootstrap ExtUtils::Mksymlists ExtUtils:
acklist
ExtUtils::testlib Fatal Fcntl
File::Basename File::CheckTree File::Compare
File::Copy File:
osGlob File::Find
File::Glob File:
ath File::Spec
File::Spec::Cygwin File::Spec::Epoc File::Spec::Functions
File::Spec::Mac File::Spec::OS2 File::Spec::Unix
File::Spec::VMS File::Spec::Win32 File::Temp
File::stat FileCache FileHandle
Filter::Util::Call Filter::Util::Exec Filter::cpp
Filter::decrypt Filter::exec Filter::sh
Filter::tee FindBin GDBM_File
Getopt::Long Getopt::Std Hash::Util
I18N::Collate I18N::LangTags I18N::LangTags::List
I18N::Langinfo IO IO:
ir
IO::File IO::Handle IO:
ipe
IO:
oll IO::Seekable IO::Select
IO::Socket IO::Socket::INET IO::Socket::UNIX
IPC::Msg IPC::Open2 IPC::Open3
IPC::Semaphore IPC::SysV List::Util
Locale::Constants Locale::Country Locale::Currency
Locale::Language Locale::Maketext Locale::Script
MIME::Base64 MIME::QuotedPrint Math::BigFloat
Math::BigFloat::Trace Math::BigInt Math::BigInt::Calc
Math::BigInt::Scalar Math::BigInt::Trace Math::BigRat
Math::Complex Math::Trig Memoize
Memoize::AnyDBM_File Memoize::Expire Memoize::ExpireFile
Memoize::ExpireTest Memoize::SDBM_File Memoize::Storable
MyClass NEXT Net::Cmd
Net::Config Net:
omain Net::FTP
Net::FTP::A Net::FTP::E Net::FTP::I
Net::FTP::L Net::FTP::dataconn Net::NNTP
Net::Netrc Net:
OP3 Net:
ing
Net::SMTP Net::Time Net::hostent
Net::netent Net:
rotoent Net::servent
O Opcode POSIX
PerlIO PerlIO::encoding PerlIO::scalar
PerlIO::via PerlIO::via::QuotedPrint Pod::Checker
Pod::Find Pod::Functions Pod::Html
Pod::InputObjects Pod::LaTeX Pod::Man
Pod:
arseLink Pod:
arseUtils Pod:
arser
Pod:
erldoc Pod:
erldoc::BaseTo Pod:
erldoc::GetOptsOO
Pod:
erldoc::ToChecker Pod:
erldoc::ToMan Pod:
erldoc::ToNroff
Pod:
erldoc::ToPod Pod:
erldoc::ToRtf Pod:
erldoc::ToText
Pod:
erldoc::ToTk Pod:
erldoc::ToXml Pod:
lainText
Pod:
lainer Pod::Select Pod::Text
Pod::Text::Color Pod::Text::Overstrike Pod::Text::Termcap
Pod::Usage SDBM_File Safe
Scalar::Util Search:
ict SelectSaver
SelfLoader Shell Socket
Storable Switch Symbol
Sys::Hostname Sys::Syslog Term::ANSIColor
Term::Cap Term::Complete Term::ReadLine::Stub
Test Test::Builder Test::Harness
Test::Harness::Assert Test::Harness::Iterator Test::Harness::Straps
Test::More Test::Simple Text::Abbrev
Text::Balanced Text:
arseWords Text::Soundex
Text::Tabs Text::Wrap Thread
Thread::Queue Thread::Semaphore Tie::Array
Tie::File Tie::Handle Tie::Hash
Tie::Memoize Tie::RefHash Tie::Scalar
Tie::SubstrHash Time::Local Time::gmtime
Time::localtime Time::tm UNIVERSAL
Unicode::Collate Unicode::Normalize Unicode::UCD
User::grent User:
went XS::APItest
XS::Typemap XSLoader attributes
attrs autouse base
bigint bignum bigrat
blib bytes charnames
constant diagnostics encoding
fields filetest if
integer less lib
locale mod_perl open
ops overload re
sigtrap sort strict
subs threads threads::shared
utf8 vars vmsish
warnings warnings::register
