CGI's Problem
saeed
Riyadh
Hi there,
Well i have some problem in CGI's files some of CGI's are working and some of CGI's are not working. Before the transferred of the website's all were working fine. After transferred the site's to Direct Admin. I am facing this problem..
(Do note... before i was also had the problem for mail() function for php.. then i rebuild the php again, and it's solved).
I am sending you the links for both which are working and which are not.
Working CGI's:-
http://www.saudilinks.com/cgi-bin/atlite/atl.cgi?ct=5
Messed CGI's:-
http://www.saudilinks.com/cgi-bin/ecards/index.cgi
any help will be much appriciated,
thnx in advance
if one script works, another doesnt confirm that you have all modules installed that the script requires.
You can check all the modules you have installed by downloading a script named 'perldiver' (search google for it). Iif you need to install extra modules you can either download the packages or use CPAN :)
Chris
