CXS guide for Directadmin
factor
USA
This guide is for CentOS 7 and CXS 11
You must have a License from the vendor for this product. I am not affiliated with csf.
You may want the EPEL repo installed. This guide does not cover that if you need it.
You must have Clamav in options.conf and installed.
./build set clamav yes
./build clamav
Once you have clamav installed
Go setup the clamd.conf
nano /etc/clamd.conf
Find and set the below fields.
# Path to a local socket file the daemon will listen on.
# Default: disabled (must be specified by a user)
LocalSocket /run/clamd.socket
# Sets the group ownership on the unix socket.
# Default: disabled (the primary group of the user running clamd)
LocalSocketGroup clamav
# Sets the permissions on the unix socket to the specified mode.
# Default: disabled (socket is world accessible)
LocalSocketMode 660
# Remove stale socket after unclean shutdown.
# Default: yes
FixStaleSocket yes
Save
systemctl restart clamd
You can use the below cmd to look for it. It took about a min or so for it to show.
find / -name "*clamd*"
looking for /run/clamd.socket
You will need to have the epel repo installed.
yum install sqlite perl-DBI perl-DBD-SQLite perl-Archive-Tar perl-IO-Zlib perl-Archive-Zip perl-libwww-perl perl-Compress-Zlib perl-LWP-Protocol-https perl-Linux-Inotify2 -y
wget https://download.configserver.com/cxsinstaller.tgz
tar -xzf cxsinstaller.tgz
perl cxsinstaller.pl
rm -fv cxsinstaller.*
echo clamdsock=/run/clamd.socket >> /etc/cxs/cxs.defaults
Now head over to DA login as admin
Go to the Plugins Section.
You should see CXS installed
Once you go thought the wizard and set your answers to the questions.
You should be presented with the CXS screen.
Troubleshooting:
If you get the big red message about Clam not being installed
Check you set the socket in /etc/cxs/cxs.defaults
Should be clamdsock=/run/clamd.socket
If it in there and still red check the /etc/clamd.conf
Make sure you saved and uncommented like above.
Hope this helps. If you find errors about perl module post back. I think I got them all but not totally sure.
Hi
Excellent guide.
I succesful installed, I got the following error:
No package perl-Linux-Inotify2 available.
THe problem is that I am unable to get on admin GUI.
Can you give me a clue?
Regards
Dependecy solved by epel-release
Hi
Excellent guide.
Regards
Great. And yes you need epel
Do you know how I can get cxs on directadmin GUI? I don't have a problem using cxs on ssh but it's more easily through DA.
If you followed my guide it’s there in admin plug-in section
https://www.configserver.com/cp/cxs.html
[SIZE=2][FONT=arial]cd /usr/local/directadmin/custombuild[/FONT][/SIZE]
[SIZE=2][FONT=arial]./build set clamav yes[/FONT][/SIZE]
[SIZE=2][FONT=arial]./build clamav[/FONT][/SIZE]
[SIZE=2][FONT=arial]nano /etc/clamd.conf[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Path to a local socket file the daemon will listen on.[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Default: disabled (must be specified by a user)[/FONT][/SIZE]
[SIZE=2][FONT=arial]LocalSocket /run/clamd.socket[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Sets the group ownership on the unix socket.[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Default: disabled (the primary group of the user running clamd)[/FONT][/SIZE]
[SIZE=2][FONT=arial]LocalSocketGroup clamav[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Sets the permissions on the unix socket to the specified mode.[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Default: disabled (socket is world accessible)[/FONT][/SIZE]
[SIZE=2][FONT=arial]LocalSocketMode 660[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Remove stale socket after unclean shutdown.[/FONT][/SIZE]
[SIZE=2][FONT=arial]# Default: yes[/FONT][/SIZE]
[SIZE=2][FONT=arial]FixStaleSocket yes[/FONT][/SIZE]
Save
[SIZE=2][FONT=arial]systemctl restart clamd[/FONT][/SIZE]
[SIZE=2][FONT=arial]find / -name "*clamd*”[/FONT][/SIZE]
looking for /run/clamd.soket
[SIZE=2][FONT=arial]yum install sqlite perl-DBI perl-DBD-SQLite perl-Archive-Tar perl-IO-Zlib perl-Archive-Zip perl-libwww-perl perl-Compress-Zlib perl-LWP-Protocol-https perl-Linux-Inotify2 -y     [/FONT][/SIZE]
[SIZE=2][FONT=arial]wget https://download.configserver.com/cxsinstaller.tgz[/FONT][/SIZE]
[SIZE=2][FONT=arial]tar -xzf cxsinstaller.tgz[/FONT][/SIZE]
[SIZE=2][FONT=arial]perl cxsinstaller.pl[/FONT][/SIZE]
[SIZE=2][FONT=arial]rm -fv cxsinstaller.*[/FONT][/SIZE]
[SIZE=2][FONT=arial]echo clamdsock=/run/clamd.socket >> /etc/cxs/cxs.defaults[/FONT][/SIZE]
Once you go thought the wizard and set you answers to the questions.
Troubleshooting:
This step dead
just follow these step
yum install dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
yum install perl-libwww-perl.noarch perl-LWP-Protocol-https.noarch perl-Archive-Tar.noarch perl-Archive-Zip.noarch perl-Linux-Inotify2 perl-Compress-Zlib sqlite perl-DBI perl-DBD-SQLite
The clamd process must run as root and create a unix socket. To do this,
edit /etc/clamd.conf and set:
User root
LocalSocket /tmp/clamd.socket
wget download.configserver.com/cxsinstaller.tgz
Error:
ClamAV socket [/tmp/clamd.socket] not found
You must install ClamAV (Clamavconnector on cPanel) or ensure clamd is running to use this product correctly
If the clamd socket is not automatically detected, and to clear this message, you must set clamdsock=/path/to/socket in /etc/cxs/cxs.defaults to the live socket location,
Thanks,
Melih
Error:
Thanks,
Melih
Yes but you wrote this:
User root
on the post.
Melih
Great guide, just a few typos to make copy-pasting easier:
looking for /run/clamd.soket -> /run/clamd.socket
find / -name "*clamd*” -> "*clamd*"
You may also consider adding epel-release to yum list, other than that it's a really helpful guide.
How can i fix this isssue?
# Clamd Error for [SCAN /tmp/cxs_H4D4oa3NhWxmkvD5PlqqCa7bEus.1]: /tmp/cxs_H4D4oa3NhWxmkvD5PlqqCa7bEus.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_T3EpkoQWHi7XGpSqmiHhxZsv6HR.1]: /tmp/cxs_T3EpkoQWHi7XGpSqmiHhxZsv6HR.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_aW7vXr0R3Ham1H0Jtq4OXzmoMLm.1]: /tmp/cxs_aW7vXr0R3Ham1H0Jtq4OXzmoMLm.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_w7gPwagZ5y8vbDGfWZz.1]: /tmp/cxs_w7gPwagZ5y8vbDGfWZz.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_8WXsVAJmBzwdGxQgtP.1]: /tmp/cxs_8WXsVAJmBzwdGxQgtP.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_4urE3Qmm9IapOIJ7Mr0y.1]: /tmp/cxs_4urE3Qmm9IapOIJ7Mr0y.1: lstat() failed: No such file or directory. ERROR
# Clamd Error for [SCAN /tmp/cxs_a5AHzMYVTYPYiohQvL6e8.1]: /tmp/cxs_a5AHzMYVTYPYiohQvL6e8.1: lstat() failed: No such file or directory. ERROR
Thanks,
Melih
How can i fix this issue?
Thanks,
Melih
Hey Melih
Do you get these errors during the Install process? OR after you have configured everything? Also if you have a license to CXS you might try their forum. They support directadmin as Beta now. https://forum.configserver.com/viewforum.php?f=26
I installed according to your suggestions. There is no issue on this process but after scanning, i think clamav does not scan.
Thanks,
Melih
in the wizards did you set all of the options you wanted like in Virus scanning?
Thanks,
Melih
1. check your out put
 cat   /etc/systemd/system/httpd.service
if you have
PrivateTmp=true
edit the file
change
PrivateTmp= true
to
PrivateTmp=false
and restart apache
service httpd restart
this should fix your issue
Hi
Thank you for this guide. i installed it and its work correctly.
whatever about "cxs ModSecurity Scanning" . i use comodo waf plugin . i enabled "cxs ModSecurity Scanning" . but im not sure it work correctly.
result of this command :
curl -F "file=@/etc/cxs/test/testexploit.php" 127.0.0.1
is:
<html>Apache is functioning normally</html>
can you please guide about it too?
Hi
is:
if you run command and cxs works(running) you should get this
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>406 Not Acceptable</title>
</head><body>
<h1>Not Acceptable</h1>
<p>An appropriate
pls check if the cxs runs whit commands
ps -aux |grep cxswatch
or
service cxswatch status
you can start the cxs whit this command
service cxswatch start
<html><head>
</head><body>
<p>An appropriate
or
CSX is active:
[root@da ~]# service cxswatch status Redirecting to /bin/systemctl status cxswatch.service ● cxswatch.service - ConfigServer cxs Watch Daemon Loaded: loaded (/usr/lib/systemd/system/cxswatch.service; enabled; vendor preset: disabled) Active: active (running) since Sat 2020-04-11 21:35:57 +0430; 23h ago Process: 23559 ExecStart=/etc/cxs/cxswatch.sh (code=exited, status=0/SUCCESS) Main PID: 23561 (cxswatch) CGroup: /system.slice/cxswatch.service ├─23561 cxswatch ├─23562 cxswatch - sleeping ├─23563 cxswatch - sleeping └─23564 cxswatch - sleeping Apr 11 21:35:57 da.domain.org systemd[1]: Starting ConfigServer cxs Watch Daemon... Apr 11 21:35:57 da.domain.org cxswatch.sh[23559]: cxs Watch daemon starting - logging to /var/log/cxswatch.log Apr 11 21:35:57 da.domain.org systemd[1]: Started ConfigServer cxs Watch Daemon.
but message after run that command is :
I thing you didn't install ModSecurity or it is disabled.
pls check /usr/local/directadmin/custombuild/options.conf
do you have modsecurity=yes ??
