DA fresh install , Problem with SSL on SMTP
shivahost
we have new server and fresh install of DA , activated let's encrypt on DA with no problem.
but SMTP not working for hostname or mail.anydomain.com
all default values in exim.conf and directadmin.conf used!
any help?
zEitEr
Super Moderator
GMT +7.00
Did you run an installation script from Directadmin? Or purchased a server with a pre-installed Directadmin?
According to this https://www.directadmin.com/features.php?id=2184 the mail_sni=1 is enabled by default for new installs.
If it's different in your case, then you might report it to Directadmin developers.
shivahost
I installed from the script. "mail_sni=1" is exist in DA.conf by default. Do I need to do something else like Cert installation?
shivahost
Sure, you need to install certs for your domains.
lets encrypt installed on my domain.com , mail.domain.com , sites loading with HTTPS .
also lets encrypt installed on my DA hostname and I login to DA with HTTPS.
but no luck!
zEitEr
Super Moderator
GMT +7.00
I would not trust remote tests that much.... what's your hostname? You may send via PM if you want to keep it in a secret from public.
zEitEr
Super Moderator
GMT +7.00
OK, I see a wrong self signed certificate is announced from your server.
Try and see whether or not
/usr/local/directadmin/scripts/letsencrypt.sh request $(hostname)
will fix it.
shivahost
will fix it.
thank you, now SMTP from my hostname accepted! but from mail.anydomain.com not working!
in my WHMCS smtp using TLS works with hostname, with SSL not works!
zEitEr
Super Moderator
GMT +7.00
You need to create certificates and include mail
.anydomain.com in Directadmin for every domain
shivahost
from userlevel in SSL page? I have created lets encrypt for the domain i sent in pm!
zEitEr
Super Moderator
GMT +7.00
I see a server-wide cert for your hostname now. It is either mail_sni is not enabled/installed, or too old version of exim.conf is used. So check the requirements and fix them: enable `mail_sni` and upgrade `exim.conf`.
shivahost
mail_sni=1 , it was a default of DA install.
exim.conf 4.5 installed by custombuild with DA fresh install.
ikkeben
Netherlands Germany
@zEitEr
Wich tool do you use for those "test" ?
zEitEr
Super Moderator
GMT +7.00
I use openssl to test it.
Try to rebuild configs of Mail related services
cd /usr/local/directadmin/custombuild./build clean
./build set eximconf yes
./build set eximconf_release 4.5
./build set dovecot_conf yes
./build exim_conf
./build dovecot_conf
and then
echo "action=rewrite&value=mail_sni" >> /usr/local/directadmin/data/task.queue
wait a couple of minutes and test again.
shivahost
thanks for your help Alex, this part solve my problem. I think because most of my accounts are restored backups from a server without these configs.
