DAreseller V1.0 has now been released !
What is DAreseller?
The first Alpha/Master multi-reseller plugin for DirectAdmin, in other words it's the DirectAdmin version of WHMreseller.
It adds 2 new levels of Reselling to DirectAdmin servers, these are Alpha & Master Resellers. Alpha Resellers can create Master Resellers, Standard Resellers and User accounts, while Master Resellers can create Standard Resellers & User accounts.
DAreseller Features
Below is a list of General Features as well as Specific Features for respective users: admin, alpha and master users
General
Root User Features
Alpha User Features
Master User Features
License Pricing
(All prices in Australian Dollars)
Monthly Price: $5.95/m
Quarterly Price: $16.95/3m
Semi-Annual Price: $31.95/6m
Yearly Price: $59.95/y
Biennial Price: $114.95/2y
Triennial Price: $159.95/3y
Owned License: $249.95
(Note only 1 license is required per server)
Trial DAreseller Today for free !
The Trial and Licensed version are IDENTICAL, they are the same software, there is no difference. Basically the licensed version can be installed and run without a license for 7 days. This is the trial period. After that if you wish to continue using DAreseller you will need to purchase a license.
Installation Instructions
cd /usr/local/directadmin/plugins
wget http://deasoft.com/dainstall.cpp
g++ dainstall.cpp -o dainstall
chmod 700 dainstall
./dainstall
rm dainstall
rm dainstall.cpp
For more information see http://deasoft.com/dareseller.php
What is DAreseller?
DAreseller Features
General
- Clean easy to use Interface
- Does NOT use PHP/MySQL
- NO WHMCS module needed
- Free automated updates
- Fast simple Installation
- Maintains its own Backups
- Automated Regular updates
- Uses lastest Bootstrap 4
- Reasonably priced
- Flexible billing options
Root User Features
- Create Alpha/Master Resellers
- Edit Alpha/Master Resellers
- Upgrade Reseller to Master
- Upgrade Master to Alpha
- Downgrade Alpha to Master
- Downgrade Master to Reseller
- Suspend Alpha/Master
- Terminate Alpha/Master
- Monitor Alpha/Master Usage
- Change Master Ownership
- Change Reseller Ownership
- Create/Edit Alpha Packages
- Create/Edit Master Packages
- Create/Edit Reseller Packages
- Import Alpha's/Masters
Alpha User Features
- Create Master/Standard Resellers
- Edit Master/Standard Resellers
- Downgrade Reseller to User
- Suspend Master/Reseller
- Terminate Master/Reseller
- Monitor Master/Reseller Usage
- Change User Ownership
- Create Resellers
- Edit Resellers
- Upgrade User to Reseller
- Suspend Reseller
- Terminate Reseller
- Monitor Reseller Usage
License Pricing
chmod 700 dainstall
./dainstall
rm dainstall
rm dainstall.cpp
