Directadmin Cron Job problem
tdldp
Hi.
I have a little cron job problem and don't know todayhow to solve it.
The job here :
20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
Makes web (http) service go down every morning at that same time and nagios starts beeping about an excessive load on server.
What does this job stand for ??? Why does it use so much load ??? How can i make it use less load, and allow therefor www service priority on it ....
Thks for your help...
The thread is so old and has no single reply here... nevertheless what exact issue are you facing there?
Hi Alex,
Well I am getting the same isse with the task.queue.
Everyday at 00:10h DA cron run a task queue that makes restart httpd service.
Mon Sep 17 00:13:01 2012] [notice] caught SIGTERM, shutting down.
Can we avoid this ?
Thanks in advance
Just add this line to /usr/local/directadmin/conf/directadmin.conf
graceful_restarts=1
Then do:
service directadmin restart
