Directadmin does not start after i tried to update it from admin panel
mahmoodmoradian
Sorry for my English.
I tried to update DirectAdmin from custombuild in control panel.
After that directadmin does not start with
service directadmin start
This is the error after trying to start:
Job for directadmin.service failed because a fatal signal was delivered to the control process. See "systemctl status directadmin.service" and "journalctl -xe" for details.
And here is the result of "journalctl -xe"
-- Unit directadmin.service has begun starting up.
Sep 02 10:48:48 server.green.ir kernel: directadmin[30320]: segfault at 8600000 ip 00000000082e940e sp 00000000ffeb31a0 error 6 in directadmin[8048000+459000]
Sep 02 10:48:48 server.green.ir systemd[1]: directadmin.service: control process exited, code=killed status=11
Sep 02 10:48:48 server.green.ir systemd[1]: Failed to start DirectAdmin Web Control Panel.
-- Subject: Unit directadmin.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit directadmin.service has failed.
-- The result is failed.
Sep 02 10:48:48 server.green.ir systemd[1]: Unit directadmin.service entered failed state.
Sep 02 10:48:48 server.green.ir systemd[1]: directadmin.service failed.
Sep 02 10:48:48 server.green.ir polkitd[24465]: Unregistered Authentication Agent for unix-process:30304:464907790 (system bus name :1.158938, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
I tried many ways ( For instance updating directadmin manually ) and searched my problem in the entire forum and I didn't get any solution to solve it.
so I will be appreciated if you could help me.
Please make sure your OS matches the license. Check /var/log/directadmin/error.log for more information.
Thank you dear smtalk.
The error file is empty!
I am using centos7 and I sure My license matches with centos7 and my IP address.
Now, what can I do to figure the problem out?
See, it's a segfault:
You might open a ticket with DirectAdmin support and let them to investigate it on your server.
I have the same problem on one of my servers if i check error.log i see this
021:09:01-10:34:08: pid 19058 killed by signal 15 (data: {"data":"\u001b[1mUpdating DirectAdmin\u001b(B\u001b[m\n","finished":false}
he
I have the same error!
2021:10:05-15:31:52: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:10:05-15:31:52: Send:sendData(/): attempted to send 1689 bytes, but only 0 were delivered
2021:10:05-15:53:48: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:10:05-16:01:04: pid 18038 killed by signal 15 (data: {"data":"\u001b[1mUpdating DirectAdmin\u001b(B\u001b[m\n","finished":false}
he
2021:10:05-16:01:04: pid 17671 killed by signal 15 (data: {"data":"\u001b[1mUpdating DirectAdmin\u001b(B\u001b[m\n","finished":false}
he
HELP!!
