DirectAdmin NOT STARTING after trying LetsEncrypt
adnanhost
Hello all
First time DA user here.
I installed DA and wanted to set up Let's Encrypt on the hostname and pasted this:
After that DA is not starting. I need help on this please. Was hoping to get this set up
[root@saturn directadmin]# service directadmin status
Redirecting to /bin/systemctl status directadmin.service
● directadmin.service - DirectAdmin Web Control Panel
Loaded: loaded (/etc/systemd/system/directadmin.service; enabled; vendor preset: disabled)
Active: failed (Result: resources) since Sat 2019-12-07 16:33:01 EST; 4s ago
Docs: http://www.directadmin.com
Process: 3651 ExecStart=/usr/local/directadmin/directadmin d (code=exited, status=0/SUCCESS)
Dec 07 16:33:01 host.domain.eg systemd[1]: Starting DirectAdmin Web Control Panel...
Dec 07 16:33:01 host.domain.eg systemd[1]: Can't open PID file /run/directadmin.pid (yet?) after start: No such file or directory
Dec 07 16:33:01 host.domain.eg systemd[1]: directadmin.service never wrote its PID file. Failing.
Dec 07 16:33:01 host.domain.eg systemd[1]: Failed to start DirectAdmin Web Control Panel.
Dec 07 16:33:01 host.domain.eg systemd[1]: Unit directadmin.service entered failed state.
Dec 07 16:33:01 host.domain.eg systemd[1]: directadmin.service failed.
adnanhost
Hello
Here is the tail of the error log
[root@saturn directadmin]# tail /var/log/directadmin/error.log
2019:12:07-16:35:02: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:35:07: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:36:02: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:36:07: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:37:01: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:37:07: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:38:01: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:38:07: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:38:58: error loading certificate: /usr/local/directadmin/conf/cacert.pem
2019:12:07-16:39:02: error loading certificate: /usr/local/directadmin/conf/cacert.pem
