zEitEr
Super Moderator
Andrea,
OK, I see now. I hope the user finally try and follow the guide.
this guide dose not work... i tried 2 day ago. and tried again.but dose not work.Try and rebuild the list of users by following this guide: https://help.directadmin.com/item.php?id=251
You can surely remove the user at system level and than edit all the config file.. not really suggested...
Maybe with the API and PHP you can write something to remove the user... but it will take time i guess..
My opinion is that fix the problem instead of delete and create the user again is the best way.
You're the only user that is having the problem, so i guess you can deal with it, is not preventing other users to use the panel.
@Alex: I did already gave him that guide
Best regards
man userdelWell, what if you tell us the user and the word that is causing the problem?
I never saw something like that so far...
Regards
) Ok, now we have a real problem to investigate.. and i really never saw something like that...
You may need to start DA with the basic skin and language in Debug mode, reach that page, and see what is going to happen: https://help.directadmin.com/item.php?id=293
Best regards
