Does not work - IF-ELSE-ENDIF skin!
Algol
Required for scripts IF in /skins/enhanced/user/filemanager/edit.html or /skins/enhanced/header.html
I've tried:
|$/usr/local/bin/php
<?php
$domain="|DOMAIN|";
if($domain=="domain.com"){echo 'ok';}
echo "Document root is: ".getenv("DOCUMENT_ROOT");
DONE|
OR:
|*if DOMAIN|
<a href="http://|DOMAIN|">Link to |DOMAIN|</a>
|*else|
Sorry, no domain to click
|*endif|
Does not work!
Algol
Does not work
Is the |DOMAIN| token being passed via GET? If not, it won't be set.
It might also be set as |domain| rather than |DOMAIN|
To see all tokens that are available on a given page, add this token for testing:
|DUMPTOKENS|
http://www.directadmin.com/features.php?id=623
John, thanks for the reply. But it does not work (
http://IP:2222/CMD_FILE_MANAGER?DOMAIN=domain.com or http://IP:2222/CMD_FILE_MANAGER?domain=domain.com
in /skins/enhanced/header.html
|*if DOMAIN|
<a href="http://|DOMAIN|">Link to |domain|</a>
|*else|
|*endif|
|*if DOMAIN|
|*else|
|*endif|
Does not work.
Only in the file manager does not work.
I would $_GET any parameter passed to.
Algol
Сorrection
Сorrection
|*if DOMAIN|
|*else|
|*endif|
|*if domain|
<a href="http://|domain|">Link to |domain|</a>
|*else|
|*endif|
DirectAdmin Support
Administrator
Staff member
Sorry, I didn't notice your mention of the file manager in your first post.
Because the Filemanager is chrooted, it will be the exception to the rule.
The skins are all pre-parsed with the FileManager because once chrooted, the scripts in the skins cannot access their parsers (Eg: it would be looking /home/user/usr/local/bin/php, thus this doesn't work).
I'm guessing this code works everywhere else but the Filemanager.. so if that's the case, unfortunately it won't work in the FM.
Algol
Is no way not to give any information to $_GET or $_POST? :(
The fact is that if we go http://IP:2222/CMD_FILE_MANAGER?TESTFUNCTION=TTTTTTT
|TESTFUNCTION|
Activated, displays TTTTTTT
And if:
|*if TESTFUNCTION|
|*else|
|*endif|
Does not work :(
