exif and imagick installation
It's a good find, and ofcourse a good recommendation to others.
Maybe it's also possible that DA can fix this in custombuild for systems with multiple php versions.
Directadmin only uses /usr/local/lib/php.ini on Centos servers, however on our newly installed Centos 7 server that is also the only one present from DA,[cut]
Don't you have /usr/local/php72/lib/php.conf.d/10-directadmin.ini? (replace php72 with your php version) Check if imagick.so is added there.
No in my case it's in /usr/local/lib/php.conf.d/10-directadmin.ini directory. And it's stated in there indeed. So you're correct.
You should also have /usr/local/php72/lib/php.conf.d/10-directadmin.ini (replace php72 with your php version).
In my case I have both /usr/local/php72/lib/php.conf.d/10-directadmin.ini and /usr/local/lib/php.conf.d/10-directadmin.ini, however it is /usr/local/php72/lib/php.conf.d/10-directadmin.ini that is used for PHP 7.2.x on my servers, and not /usr/local/lib/php.conf.d/10-directadmin.ini
No I don't on both newly installed servers and neither on both VPS systems. Maybe because we only use 1 php version.
Strange. I am also only using one PHP version (php-fpm). Maybe DirectAdmin has made som changes that only affect new installs.
Little update, I now also see it loaded in /usr/local/lib/php.conf.d/10-directadmin.ini and /usr/local/php73/lib/php.conf.d/10-directadmin.ini (for mod_ruid and my php-fpm 7.3).
And it complained it was now being loaded twice, so I removed my instances in the php.ini's. I guess CB had put it there after some update/rewrite.
I notice that Centos8 use GraphicsMagick (the latest forked of ImageMagick) and don't have ImageMagick repo by default. Hope that custombuild can include this as well. Thanks.
thanks
looks like it only took 18 years..
You're probably in this forum because a WordPress Site Health Analysis provided a Recommended Improvement:
"Warning The optional module, Imagick, is not installed, or has been disabled." (FYI, the word "warning appears in yellow microprint and appears to be a yellow 'em-dash'; you can only see the term by copy/paste into a text editor.)
The ImageMagick extension, called Imagick when referring to the PHP extension, is a native PHP extension to create and modify images using the ImageMagick API. Do I/you need this??
I figured the easiest way to add the php extension would be through WHM -> EasyApache 4, but don't bother, Imagick is not there.
You can add it through WHM -> Software -> Module Installers -> PHP PECL -> (search) Imagick
But:
1) the latest version is 3.4.4 (2019-05-02)
"The 3.4.4 release is intended to be the last release (other than small bug fixes) that will support either PHP 5.x, or ImageMagick 6.x. The next planned release will be PHP > 7.0 and ImageMagick > 7.0 at least, if not higher."
[see: http://pecl.php.net/package/imagick]
[see: http://pecl.php.net/package-changelog.php?package=imagick&release=3.4.4]
2) Confusingly, the Imagick Extension description also refers to a similar name product - "ImageMagick" with a different version number; don't confuse these:
"Imagick is a native php extension to create and modify images using the ImageMagick API. This extension requires ImageMagick version 6.5.3-10+ and PHP 5.4.0+."
3) I noted, through the above pathway and search, that Imagick 3.4.4 was installed in my php 7.2 folder [/opt/cpanel/ea-php72/root/usr/lib64/php/modules] but not my 7.3 folder. I remain hesitant to install it in 7.3 as it appears Imagick 3.4.4 is EOL and I have not found any Imagick 7.x versions.
Thus, I have decided not to install it in php 7.3 and will await the availability of the 7.x versions.
But this is not WHM nore cPanel and imagick as well as Imagmagick can be installed via DA's custombuild.
Got one of them running on Centos 7 with php 7.2.
Richard, maybe you can advise me on this ?
I installed Imagemagick with custombuild on a centos 7 server, resulting:
[root@qwsrv55 php.conf.d]# convert --version
Version: ImageMagick 7.0.10-18 Q16 x86_64 2020-07-23 https://imagemagick.org
Copyright: © 1999-2020 ImageMagick Studio LLC
License: https://imagemagick.org/script/license.php
Features: Cipher DPC HDRI OpenMP(3.1)
Delegates (built-in): bzlib freetype jng jpeg png webp xml zlib
Now i need to add delegates, f.i. for tiff format.
I am looking hw to achieve that ?
regards, Cees.
Not by default, as it's disabled by default, but yes, it can be built, it's as easy as:
./build set imagick yes
./build imagick
custombuild did not like ./build set imagick yes
imagick is not a valid option.
That's an old command. It's not done like that anymore.
Try like this:
./build set_php "imagick" yes
./build "php_imagick"
But they changed ./build too so if ./build gives some notice, then try like this (from any directory):
da build set_php "imagick" yes
da build "php_imagick"
Not to wake the dead, but I'm having a similar issue. As most of you, I saw the notice on WP and went bashing around. I have ImageMagick enabled in the CB settins. WP shows the correct version. Everything is working...almost.
For one, I think it's worth an update in this thread. I'm not sure if you manually change the delegates, but ImageMagick has something like 100 now. Maybe WP knew something we didn't when they started suggesting it. IDK, but GD only supports like 5.
That said, one that ImageMagick CAN support is AVIF. For some reason, the CB utility doesn't call whatever dependancy is necessary for that to work. I think this needs to be a feature update. I'm not sure what needs to be installed or what --with-XX to use if it doesn't get patched. Any ideas how to get AVIF support installed when ImageMagick is built? That would be excellent. (the log currently does not show that format built).
Too late... I'm awake now and will haunt you in your sleep. :D :D
Anyway, did you check this thread here as of this post? https://forum.directadmin.com/threa...gick-using-custombuild-2-0.67505/#post-355968
Found it via Google and it says AVIF support is already present, with the command mentioned there you can check.
If it doesn't work for you, that thread is a bit older, but more to the point of what you need, so maybe up that one. :)
